Home > In Car Electronics (L322) > Speakers
Paulhh
Scotland 2002 Range Rover Vogue 4.4 V8 Epsom Green
Is No 2 the Amp that I need which would leave me with just a Sub to get plus speakers.
[/url][/list] 2002 Vogue Epsom Green with Ivory Leather.
Discover 2 V8
Discovery 2 TD5
Discovery 1 V8
Audi S4 (2005)
Audi S4 (2000)
Post #169931 4th Feb 2013 10:35am
Baris
Yes, you have DSP. Time for some fine tuning on the DSP option. Adjust the DSP with the tones set to centre.
Post #169937 4th Feb 2013 10:44am
Paulhh
I did set the graphic equaliser to the central positions and it definately sounds better. I will have to look at a speaker upgrade package I think. 2002 Vogue Epsom Green with Ivory Leather.
Discover 2 V8
Discovery 2 TD5
Discovery 1 V8
Audi S4 (2005)
Audi S4 (2000)
Post #169939 4th Feb 2013 10:46am
Baris
No, put the tone settings to the centre, and adjust the equalizer.
some examples and info.
80 200 500 1k 2k 5k 12k
+3 -1 +1 +2 +4 +6 +7
http://www.m5board.com/vbulletin/m5-e39-e6...tings.html
http://www.m5board.com/vbulletin/e39-m5-e5...tings.html
Always use a good source for music, ie audio discs, or mp3. Dont expect much from radio, no matter how much you spend.
Post #169948 4th Feb 2013 11:23am
Mr Tee
Mr Baris, YHM.
Post #169953 4th Feb 2013 11:52am
Paulhh
Thanks for your help Baris 2002 Vogue Epsom Green with Ivory Leather.
Discover 2 V8
Discovery 2 TD5
Discovery 1 V8
Audi S4 (2005)
Audi S4 (2000)
Post #169989 4th Feb 2013 1:43pm
MarkNL
Netherlands 2007 Range Rover Vogue SE TDV8 Java Black
This message is from 2001, copied from the M5 lforum link.... must be the oldest thread revival ever.... but the content is great !!
On the equalizer settings with DSP... please start with step 1....
Step 1 is the TONE controls: I like mine at zero, but you should only use these to vary the sound depending on the source, Radio, CD, cassette... once you have set the EQ.
Step 2: Try this as your base. It was done by a fellow who measured his car interior with a "pink noise generator" to achieve the flattest, most even frequency curve. This is what you when listening to music. Minimal coloration.
Here are the results:
With TONE and DSP sliders to Center/"0" position, the M5's sound system generated too much energy at (Hz) 30, 80 and 120, and not enough at 480 Hz and way too much at 1 Khz. Above 1 kHz the frequency response was generally low.
On the DSP EQ, the following settings generated an almost even (flat) distribution. Almost because, hey it's a car not a sound studio!
80: 0
200: -2
500: +4
1K: -7
2K: +3
5k: +5
12k: +5
Room and Echo : 0 (This is a personal preference. Myself, I hate adding something the "band or artist" didn't add themselves)
Give it a shot, and tell me what you think....
My comment: Well, I think its just right, THANK YOU !!
 Mark Offringa
Utrecht Netherlands
2007 L322 / 3.6 TDV8 / Vogue / Java black
2002 Mini Cooper / 1.6 116 hp / Red + white roof / the magic back-up Smile
Gone:
2002 L322 / 4.4 V8 / Vogue/ Adriatic blue
2000 Audi A6 / V8 4.2 / Brilliantschwarz
2003 L322 / TD6 HSE / Adriatic blue
Post #521564 12th Jul 2019 11:21am
