Home > Technical (L322) > Brembos....
Page 2 of 3 <123>
Just get a cheap punch pin set from bnq or the like as there is a perfect size in most for the brembo pins. Once they are loose they close out easy enough Smile
Also any pads should do the job Smile I got some Mintex from eBay for mine recently an they are great Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #169815 3rd Feb 2013 9:10pm
Because they are 4 pot calipers you cant get a c clamp on them.
Search on youtube for brembo pad change, there is a few vids for an evo but the calipers are similar.
All will become clear. A drift is like a punch with a long straight end. Search for the vids and you will see what i mean, or what you need to do/tools required. Honestly really easy. Tbh i would get the pad sensor as they arent much money and yo may break it......
http://m.youtube.com/watch?v=iTluwZB5QYE clicky Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #169816 3rd Feb 2013 9:11pm
Googsy
Thanks chaps Bow down Bow down
So I take it the rears are more traditional as in I can use c clamp.? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #169821 3rd Feb 2013 9:27pm
Yes they are "more traditional" Thumbs Up
IMHO I wouldn't use mintex pads in the brembo's as they in my experience fade too much and make the brakes feel warped when hot... Have found this on three different customers cars... All solved by fitting Brembo pads... Just my two penneth worth Thumbs Up
Post #169830 3rd Feb 2013 9:48pm
Googsy
Last question chaps seems to be warnings about compatibility are there diff sizes for the 3.6tdv8 that have Brembos mine is 08?
Will these do ebay item no. eBay Item No. 270910655836
I presume when they say a set they mean 4 pads rather than 2 . Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #169843 3rd Feb 2013 10:31pm
If the technical pic is anything to go by then they are wrong. Should be kinda square.
I think the lr part no is sfp500070. There is nothing that can't be fixed with a hammer😜😜
Post #169847 3rd Feb 2013 10:54pm
These might be worth a call if they are "brembo" at that price, it does say should be over 120 notes.
Never heard of the company but a quick call to check availability etc....... they do seem to have a different part no stamped on them but a quick call should sort out wether genuine. and cheap.....
http://www.ribblevalley4x4.com/allmakes/AM_SFP500070.html
was having a quick search around myself and found them. There is nothing that can't be fixed with a hammer😜😜
Post #169854 3rd Feb 2013 11:33pm
Ribble valley are good... Very good price too Thumbs Up
Post #169867 4th Feb 2013 8:10am
Ribble Valley are very good and will beat almost any quote i have given them for anything LR related thus far Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #169922 4th Feb 2013 10:22am
Googsy
Thumbs Up Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #170004 4th Feb 2013 2:55pm
Ordered some cos at that price, if they come as Brembos they are a bargain and mine need doing soon. Even if they arent Brembo then they are a bargain anyhow and my fronts still need doing. There is nothing that can't be fixed with a hammer😜😜
Post #170079 4th Feb 2013 8:00pm
Googsy
I bought Pagid front and rear with sensors 79.00 including delivery.
Tomorrow im getting axle stands punch set and copper grease Thumbs Up
Thanks for all your help guys hopefully will be as easy as it looks. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #170089 4th Feb 2013 8:16pm
Pagid are a great make even for standard pads. If you find they wear quicker than you like ask them for their Blue pads Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #170109 4th Feb 2013 8:43pm
Googsy
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #170129 4th Feb 2013 9:17pm
Did a write up on here on how to do the rear pads.
It is as well quite straight forward, you will need quite a slender spanner to fit onto the caliper sliders couldnt get my standard 13mm to fit and had to use my bahco adjustables. There is nothing that can't be fixed with a hammer😜😜
Post #170144 4th Feb 2013 10:09pm
Page 2 of 3 <123>
