Home > Technical (L322) > Brembos.... |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
My pads need changing too so I watch this thread with interest . I think there is a how to from Bodsy on Disco3 in wiki. Not the same as RR but similar. Present :2008 TDV8 HSE
2nd Feb 2013 4:22pm |
My pads need changing too so I watch this thread with interest . I think there is a how to from Bodsy on Disco3 in wiki. Notbtge samel as RR but similar. Present :2008 TDV8 HSE
2nd Feb 2013 4:35pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Easiest of all the pads to change gents... Remove the resevoir cap first! Then Ideally you need a long punch to knock out the pins, clean and copper grease the spring and pins, pull out one brake pad only! push back the 2 pistons on that side, copper grease the rear of the pad and slide it in... Repeat with the 2nd pad, slide the first pin back in and tap home with a hammer and punch, refit the spring and slide in the second pin... Easy peesey
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8662 |
Cheers craig, how do you push the pistons in? Pair of grips on pad edge and caliper and squeeze? There is nothing that can't be fixed with a hammer😜😜
2nd Feb 2013 4:47pm |
I have a special tool but a screwdriver through the holes that hold the pins will do or like you say a pair of grips on the old pad... Just dont scratch the caliper! |
2nd Feb 2013 5:10pm |
Coolio.
2nd Feb 2013 5:20pm |
Thanks Craig aint forgotten your tubes!
2nd Feb 2013 5:31pm |
I think the NSF doesn't have a brake warning sensor so do that side first... If you are to re-use your sensor then remove it carefully! 40% of the time they snap so if that will leave you in trouble then order one before you attempt the job |
2nd Feb 2013 5:56pm |
I think there is a bit of meat left on the pads, so just a copper slip job. There is nothing that can't be fixed with a hammer😜😜
2nd Feb 2013 9:05pm |
Done the fronts, easy job actually, craig was right brembos are a piece of p155. Knock out the two pins with a drift, top one first, take care of the spring, squeeze the pad towards the caliper with some grips and reomve the pads.
3rd Feb 2013 3:35pm |
Bet there's no copper in the rears...
3rd Feb 2013 5:18pm |
probably right, its easier to do them my self than take them back to the stealer. They put new pads in when they did the calliper and i bet they didn't put any paste in there.
3rd Feb 2013 6:51pm |
right I think i will try this. Have see some on eBay brembo, ebc, and mintex are these okay as replacements? I'm going to try and reuse sensor although will buy one just in case . Oh and what's a drift? I was going to buy a c clamp to push piston back in. Present :2008 TDV8 HSE
3rd Feb 2013 9:06pm |
