Home > Technical (L322) > Fuel pump noise |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35424 |
John [47p2] has suggested knocking the pump with a screwdriver to see if its jammed.... ... - .- -.
31st Jan 2013 10:20am |
You don't need to knock 7 bells out of it, just a few light taps with a screwdriver or spanner |
31st Jan 2013 10:22am |
daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201 |
Thanks guys, I have tried that but didn't hold much hope cos the pump is deep inside the fuel tank or am I missing something? Is there a secondary pump on the petrol also? 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie |
31st Jan 2013 10:30am |
SteveyD Member Since: 11 Dec 2012 Location: Cheshire Posts: 352 |
Your knocking the wrong pump. Spend 5 mins reading this, just shows you what a helpful bunch this forum has!
31st Jan 2013 11:47am |
Cheers Stevey, I had read that but I think it is only the diesel that has the external secondary pump.
31st Jan 2013 12:41pm |
Looking at Rave the petrol engine only has one pump from what I can see. Still worth giving it a sharp chap with a hard object to see if it kicks into action |
31st Jan 2013 12:47pm |
Thanks John, I had another go at that this morning, no joy I'm afraid so it looks like I am gonna have to strip it all out, wish me luck lol. 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie |
31st Jan 2013 2:10pm |
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 |
Had this problem 2 years ago and the lads are correct,the v8 only has one pump and is on the righthand side.Lift the seats and you can actually thump it with your fist and that will free it if its sticking.It will run for a little bit and then stop again most likely.Saint v8's write up is all you'll need and another bit of advice is to change the fuel filter if your changing the pump aswell.
31st Jan 2013 3:39pm |
Thanks for the replies guys, thumps and whacks didn't work so I will be stripping it down.
31st Jan 2013 6:12pm |
if the pump is working you should have heard a noise from it when you listened to it.The second option is to do a pressure test which can be found in the :
31st Jan 2013 10:01pm |
Well thanks for all the help and advice guys.
4th Feb 2013 7:14pm |
Saint.v8 Member Since: 13 Jun 2012 Location: UK< Surrey - Near the Middle Close to Some Green Bits Posts: 94 |
Glad you got it sorted...and I am glad my report helped...!! |
4th Feb 2013 8:16pm |
Very very helpful thanks Saint.
5th Feb 2013 7:50am |
