Home > Technical (L322) > Fuel pump noise
daz62
United Kingdom 2003 Range Rover Vogue SE 4.4 V8 Oslo Blue
Fuel pump noise
Sorry for the dumb question but my car a 03 4.4 petrol, the engine turns over but won't fire up.
I swapped the relays out in the rear fusebox to no avail then I stripped the back floor out to try to listen to the fuel pump, it is silent, should I be able to hear anything?
Any ideas or further tests I can do before I resort to following Saint V8's excellent post on how to replace my fuel pump. 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #169066 31st Jan 2013 10:07am
John [47p2] has suggested knocking the pump with a screwdriver to see if its jammed.... ... - .- -.
Post #169068 31st Jan 2013 10:20am
You don't need to knock 7 bells out of it, just a few light taps with a screwdriver or spanner Thumbs Up
Post #169070 31st Jan 2013 10:22am
daz62
Thanks guys, I have tried that but didn't hold much hope cos the pump is deep inside the fuel tank or am I missing something? Is there a secondary pump on the petrol also? 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #169072 31st Jan 2013 10:30am
SteveyD
England 2003 Range Rover Vogue Td6 Bonatti Grey
Your knocking the wrong pump. Spend 5 mins reading this, just shows you what a helpful bunch this forum has!
http://www.fullfatrr.com/forum/topic15918-30.html
Post #169093 31st Jan 2013 11:47am
daz62
Cheers Stevey, I had read that but I think it is only the diesel that has the external secondary pump.
Can anyone confirm yes or no please? 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #169102 31st Jan 2013 12:41pm
Looking at Rave the petrol engine only has one pump from what I can see. Still worth giving it a sharp chap with a hard object to see if it kicks into action
Post #169103 31st Jan 2013 12:47pm
daz62
Thanks John, I had another go at that this morning, no joy I'm afraid so it looks like I am gonna have to strip it all out, wish me luck lol. 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #169135 31st Jan 2013 2:10pm
rathbranV8
Ireland 2002 Range Rover SE 4.4 V8 Oslo Blue
Had this problem 2 years ago and the lads are correct,the v8 only has one pump and is on the righthand side.Lift the seats and you can actually thump it with your fist and that will free it if its sticking.It will run for a little bit and then stop again most likely.Saint v8's write up is all you'll need and another bit of advice is to change the fuel filter if your changing the pump aswell.
As a matter of interest how many miles are on your Rangie,the pump seems to fail around the 100k mark
Post #169155 31st Jan 2013 3:39pm
daz62
Thanks for the replies guys, thumps and whacks didn't work so I will be stripping it down.
I really would still like to know if I should be hearing the pump or not before I start to pull it apart, it is currently silent when I think I should be hearing something buzzing with the ignition on.
Rathbran I am at exactly 125k miles. 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #169192 31st Jan 2013 6:12pm
rathbranV8
if the pump is working you should have heard a noise from it when you listened to it.The second option is to do a pressure test which can be found in the :
Wiki>online workshop manual>Range Rover L322 Workshop Manual - Service Procedures>fuel delivery system v8>fuel system pressure test.
this will at least make sure your on the right track having done all the electrical guesswork,but me thinks you are at the mileage thats on her Daz Thumbs Up
Post #169242 31st Jan 2013 10:01pm
daz62
All done
Well thanks for all the help and advice guys.
I swapped the old fuel pump for a new one from Eurocarparts (£155 all in after 25% discount) I followed Saint V8's brilliant instructions and everything went to plan.
She fired up straight away.
Thanks again everyone, I saved a small fortune. 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #170067 4th Feb 2013 7:14pm
Saint.v8
Location: UK< Surrey - Near the Middle Close to Some Green Bits
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Glad you got it sorted...and I am glad my report helped...!!
Post #170090 4th Feb 2013 8:16pm
daz62
Very very helpful thanks Saint.
For what it's worth my fuel pump was totally knackered, no warning it just stopped working, when I put a current onto it it was dead. 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #170168 5th Feb 2013 7:50am
