![]() | Home > Technical (L322) > OK What Now....?? |
Saint,
Saint.v8 Member Since: 13 Jun 2012 Location: UK< Surrey - Near the Middle Close to Some Green Bits Posts: 94 ![]() ![]() ![]() |
Many thanks DB....
I wouldn't worry too much about the EBV fault. I have that on mine all the time, also checks out on the IID Tool and the GAP guys say not to worry about it too. I agree with DolphinBoy, problem appears to lie with the ABS. This will set off all the other faults |
Lock to Lock did not reset the warnings...as you say the ABS ECU is looking like the first port of call...I will grab some contact cleaner from stores at work and a tooth brush and take a look see. |
IWC1 Member Since: 11 Jan 2013 Location: suffolk Posts: 18 ![]() ![]() ![]() |
Hello Saint,
You could also have a battery cell failing (internal short circuit) dropping the voltage momentarily generating the "random" faults. MY 2010 5.0 SC Galway green and sand interior!!
As above with the driving cycle you have mentioned the battery wouldn't have been topped up enough and could have a faulty cell.
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 ![]() ![]() |
I hate the Transfail safe mode message |
Thanks for all your replies.
Havank Member Since: 05 Apr 2007 Location: Woking - Surrey Posts: 193 ![]() ![]() ![]() |
I think its moisture related. the car cannot stand moisture |
So....lunch time came and went, I made the trip to the car park - 10 minute walk from the office!
dude hate to p*ss on ur theory my setup is in the same location as urs and i havent had them issues |
Clutching at straws then...!! |
Is it the outflow or inflow from the vaporiser that runs underneath it?
