Home > Maintenance & Mods (L322) > An upgraded dual battery idea. |
wats39 Member Since: 08 Jul 2012 Location: fife Posts: 77 |
Pm sent. cheers '04 td6 se
26th Jan 2013 11:22pm |
Why not just use a VSR in the circuit to charge the second battery
26th Jan 2013 11:24pm |
barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213 |
@47p2
27th Jan 2013 12:01am |
Laurie915 Member Since: 11 Sep 2011 Location: Canberra Posts: 72 |
The link below shows photos and details of a custom L322 twin battery setup we are using in Oz. Great product and customer service !!! As you will see when you read the posts it took a while to get it sorted, but all questions were asked and replied too.
27th Jan 2013 12:55pm |
Interesting how Mercedes tackle the twin batteries in the W211
27th Jan 2013 1:28pm |
Barracuda, the voltage sensitive relay should work. it will join both batteries above 13.7v ie when the engine is running and charging and then disconnect them when the voltage drops below 12.8v. dont see any benefit over a standard relay though other than possibly not needing to have a switched wire from the ignition. there are many ways to have a dual battery setup, just depends how much you want to spend. having looked at the wiring diagrams from nicedayforit there are just the 2 main + cables from the battery. one to the starter/alternator and the other to the rest of the vehicle. it is between the rest of the vehicle cable and the battery that you will have to put the relay, whichever one you choose. '04 td6 se
27th Jan 2013 3:21pm |
Yes, just had a look at the wiring diagrams, kindly given to me by nicedayforit.
27th Jan 2013 3:55pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3969 |
Glad you've found the diagrams of use.
27th Jan 2013 4:31pm |
But as the aux battery will still be connected to the systems this wont be an issue, as the aux battery will be powering them instead of the main batt + aux batt powering them when the vrs is made. |
27th Jan 2013 4:43pm |
You're right
27th Jan 2013 4:56pm |
Thats it, it wont matter.
27th Jan 2013 5:16pm |
33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381 |
Contact this guy
31st Jan 2013 1:59pm |
Don't see what the problem is venting a battery. Drill a hole in the bodywork, give the bare metal some paint to protect it, fit a grommet and push the vent tube through the grommet. |
31st Jan 2013 2:23pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
Or one could tube out through one of the existing grommets behind the bumper (trailer wiring etc) .
31st Jan 2013 6:34pm |
