![]() | Home > Technical (L322) > Ticking noise from heater |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Welcome.. |
DaWalley Member Since: 24 Jan 2013 Location: Cheshire Posts: 42 ![]() ![]() ![]() |
Hey! Thanks for such a quick reply!
I don't think there is anything wrong, it's just the noise it makes as it pumps.
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
Definitely sounds like the FBH fuel pump, perfectly normal and nothing to worry about |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Ditto, its the fbh pump, totally normal, will stop when thr weather is warmer and the fbh is not in use.
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 ![]() ![]() ![]() |
I have the same noise from the same area on my TD6...
Thanks for all the replies and advice! Can't believe how good this forum is! What an introduction! |
elmer Member Since: 24 Mar 2013 Location: Spain Posts: 17 ![]() ![]() |
hello everybody,
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 809 ![]() ![]() ![]() |
Sorry,i�ve a question.
The fbh is a separate heater located under the battery tray/behind the front wing. it was fitted as standard on 08my tdv8 cars so your car should have it. It will operate in various conditions, these are in the wiki for reference, it should not have anything to do with you steering wheel element. But ticking coming from the rear door area is a separate fuel pump pumping diesel to the heater which it then burns to heat the water in the cooling system and into the cabin heater matrix.
Thanks.
Yes it pumps the diesel to the heater.
