Home > Technical (L322) > Towbar help
Durham4416
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
Have you just welded around the area where it joins together? Is this enough to stop it coming apart?
Post #167291 24th Jan 2013 8:12pm
Durham4416
Post #167292 24th Jan 2013 8:15pm
wats39
Scotland 2004 Range Rover SE Td6 Alaska White
Its just welded each side where the triangle bits are and a bit on the front and back so not completely welded. just make sure its a good weld and it will be fine. mine has towed some heavy trailers and not a problem. you should try and make sure the two parts are properly connected first though if possible then the weld is only an extra precaution. '04 td6 se
'63 land rover s2 200tdi
'04 mk indy kitcar bike engine
Post #167298 24th Jan 2013 8:30pm
simon1233
You could also contact westfalia to see if there is a service kit to replace the lock and mechanism? I should imagine that they will provide something like this.
Post #167302 24th Jan 2013 8:34pm
to separate you need to pull out the wheel before turning....... looks bust, but if you can get it out then there are a few necks on their own for sale for about £100.
or for occasional use you could go for http://www.ebay.co.uk/itm/Westfalia-Towbar...3b51d4eec/
they are removable and normally come with a bag to keep it in.
£205 notes for a new neck and reciever from PF jones via ebay... There is nothing that can't be fixed with a hammer😜😜
Post #167334 24th Jan 2013 9:35pm
