![]() | Home > Maintenance & Mods (L322) > Altenator failure? |
jonlewis Member Since: 06 Nov 2012 Location: UK Posts: 308 ![]() ![]() |
Mine is on 42k and went with no warning today 2011 Stornaway Grey 5.0SC Autobiography |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Mines just hit 28k so something to forward to then.
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 ![]() ![]() ![]() |
Mine went at about 90k. Really quite common according to the tech and was repaired under warranty .
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
Mine went around 50K when the car was 4 years old, was replaced under landrover approved used warranty. The workshop manager at the time told me the alternator used on the earlier TDV8's was not the best and that mine was replaced by the newer 'improved design' model. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Right, im going to give the local indy a call and get a price, quite a bit of time left yet, and its unlikely to go pop in the last 9 days of warranty i have left.
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 ![]() ![]() ![]() |
92k when mine went 2007 TDV8 Vogue SE Java Black |
I'm probably tempting fate here but I'm on 100k with original alternator.
schnauzer Member Since: 28 Aug 2012 Location: on top the Mendips Posts: 8 ![]() ![]() ![]() |
Mine went last week, no warning at 61k. Managed to get it recovered after a wrangle with the RAC from Bath to Guava in Guildford who as usual gave a very efficient and quick service. one life ,live it. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
Mine went around 60k too - completely drained the battery too so the car was dead. Fortunately, we were at home.
Ive seen the thread about repairing the diode pack, it looked ok to do, the question then is how easy is it to get the altenator off the car? That would seem to be the tricky bit, not neccessarily the diode pack.
I believe on the TDV8 it involves removing the rads to gain access to the alternator. |
It does indeed mean removing radiators although the air-con rad can be left in place as long as you're careful. Saves a re-gas as well. About 4 hours if you're lucky. |
Just spoke to the indy, �500 notes to swap, and aparently you have to remove some cooling hoses too so it will drop the coolant. Pig of a job, quoted 4 hours but said would probably take 6. Not a do it on the drive job There is nothing that can't be fixed with a hammer😜😜
Polux Member Since: 02 Jun 2009 Location: UK Posts: 242 ![]() ![]() |
mine a 4.4 went just now at 55k 7 years old, part was �495 fitted �750 |
