Home > Maintenance & Mods (L322) > Hands Free
sandy
2004 Range Rover Vogue Td6 Buckingham Blue
Hands Free
Hi
Can anybody tell me the best hands free phone kit for my 2004 Vogue ?
Post #16445 11th Apr 2010 4:00pm
M44K TS
Best one would probably be the Range Rover retro-fit bluetooth system.
However, I went for a standalone Nokia kit with the seperate hidden speaker as I didn't want to try and butcher the wiring harness for the likes of a parrot system. It works very good, got the mic. mounted to the side of the drivers sun visor and it's a very clear sound.
http://www.midnightclub.ie/shop/in-car-dev...od_24.html 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #16446 11th Apr 2010 4:08pm
SteveMFr
Site Sponsor
The best is OEM (well BMW, actually). If you have the wiring in the car, it's also the least amount of work. You'll need the ULF-module, a BT antenna, the mic and a pairing button at minimum. The oem console and cradle are a nice touch too (cradles are avail for all sorts of phones)
Not cheap though at about GBP550 (incl console) with new parts - with used parts you can halve that, though. And then you can scroll through the phone book in your instrument cluster using the steering wheel controls and ask your phone to dial a number by voice commands.
I might be able to help with parts/guidance if you're interested.[/i]
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #16511 12th Apr 2010 9:22pm
daz
United Kingdom 2004 Range Rover HSE 4.4 V8 Tonga Green
hi, i had a bury hands free bluetooth kit fitted by avmobile for �180 it sit up on the dash great kit, better by far then any of the oem kits, had the 08 i drive in my m5 before and whilst that was ok no where near the quality of the bury, voice activation is very very good.
the only down side is it is not built in the same way as an oem kit.
cheers
Post #16542 13th Apr 2010 9:23pm
StevieH
Depending on budget I would suggest the following:
�5-10 - Go to Maplin or Tesco and buy a cassette adapter, plug it in and you have instant handsfree threought the stereo system...also great for playing your MP3 music from your phone too.
�250 - Parrot system which again allows music streaming throught th stereo speakers also.
I have used both these methods and found they work well, dare I say it better even than the factory install system that my car came with...also I have a Sony Ericson X10 and can do SatNav, music and phone calls all throught the Parrot and mine is a 2004 MY car too
Post #16548 13th Apr 2010 11:16pm
Have only ever heard positive things about the Parrot systems if that helps? Discovery 4 HSE
Post #16555 14th Apr 2010 9:18am
