Home > Maintenance & Mods (L322) > Brake discs replacement
kin
England 2006 Range Rover Vogue TDV8 Zermatt Silver
At what mileage on average does the disc brakes needed replacing? I've heard that once the discs worn down over 1mm, discs would need replacing, is this true?
Mine has done 36k, and I could feel the edge of the disc deffo worn down at least 1mm.
Also, I've heard that its best to change gearbox fluid at 40k, even tho its supposedly sealed for life.
I ask the question, because the dealer have promise a full service FOC..
Any advice would much appreciated Thumbs Up
Post #1645 10th Dec 2008 7:17pm
Full fat not diet
England 2004 Range Rover Vogue Td6 Zermatt Silver
If in doubt n brakes i would change them. i cant remember exactly when i changed mine but i think it was around 40,000 miles. Generally it depends on your driving style and the sort of journeys etc rather than mileage. If there is a lip on the Disc it sounds like it is tome to renew especially if paid for by dealer
Post #1647 10th Dec 2008 7:24pm
kin
Thanks, but somehow I got a feeling that it would not be replaced as this service is FOC...
Post #1649 10th Dec 2008 7:29pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
as for gearbox oil for the sake of a couple of hundred quid itll give peace of mind and saves the cost of a gearbox overhaul at like 2k money well spent onto no6 Range Rover
Everyone needs a hobby
Post #1652 10th Dec 2008 7:46pm
kin
Does it really cost a couple of hundred pounds just to change gearbox fluid? Shocked
Post #1653 10th Dec 2008 7:49pm
speedymarktd6
thats pretty good when you consider what you are replacing youve got a big gauze filter a few seals and a new pan gasket then the oil which i believe you cant use std ATF red fluid i just get everything from LR the fluid is bout £100-£150 could be really special but i doubt it the only reason i get it all from LR is i know it all pukka and tested stuf onto no6 Range Rover
Post #1654 10th Dec 2008 7:54pm
kin
Ahh..I see, I thought it has a drain plug at the bottom, and a fill plug somewhere half way up.
...so it has its own oil filter, and it does not have a drain plug? Is that right?
Post #1655 10th Dec 2008 8:03pm
If like me you're used to working on old Land Rovers then yes it was just a case of a drain plug and a filler hole, dead easy!
Sadly, things have advanced a little now.
I remember doing this job on my Series 3 and seeing lots of bit of metal teeth in the drained oil....it didn't seem to bother the old girl, built to last back then! Discovery 4 HSE
Post #1659 11th Dec 2008 10:18am
kin
Well...took it down today for a free service, and asked for the gearbox fluid change, he told me fluid alone would cost in the region of £110-£120. I guess the fluid must be really good then, anyway I've told him to go ahead, and also have those side steps fitted as well Thumbs Up
I've also asked him for a quote on front discs and pads fitted, he quoted me around £350 fitted, I think that is very reasonable, do you guys think its about right?
Post #1662 11th Dec 2008 12:42pm
read this first...
http://www.fullfatrr.com/forum/topic125.html Discovery 4 HSE
Post #1663 11th Dec 2008 1:01pm
kin
Thanks again Thumbs Up Do you know of any Range Rover indy in the Manc area ?
I will of course still be taking it to the dealer for servicing, but minor jobs wil be taking it to the indy...
Post #1664 11th Dec 2008 1:34pm
Sadly I don't, but the Indy I take mine too is NOT a Land Rover specialist, you don't need to be to fit brakes, any grease monkey can do those.
If I were you I'd be looking for a friendly local garage that does tyres, exhausts brakes etc and go down, have a bit of banter with them and they'll soon do deals for you.
For example, my local place does all 4 wheels balanced for me for £20. My local LRD wanted £23+VAT each corner! Discovery 4 HSE
Post #1665 11th Dec 2008 1:54pm
Full fat not diet
I also had my Pads / Discs done by the local friendly garage - Far cheaper and more reliable - Dont Forget the Brake Sensors though?!?! ithink from memory they were around £12
Also Kin what have they quoted for fitting the steps?
Post #1666 11th Dec 2008 3:26pm
kin
They quoted me £400 fitted, as part of the deal of buying the TDV8 Smile
BTW someone over in the PH forum recommended this Landrover indy
http://www.a1-landrover-specialists.co.uk/
Anyone has any experience with them?
Post #1667 11th Dec 2008 4:54pm
