![]() | Home > Technical (L322) > Engine management light/ range rover l322 2005 model TD6 |
bulb |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
HI
bluetoby131 Member Since: 14 Jan 2013 Location: Bournemouth, Dorset Posts: 5 ![]() ![]() ![]() |
Hi have done oil and filters myself , but i am thinking of having an anuall service by garage soon, there are a couple of aftermarket guys locally, and no light has never worked, i recently had it brought to my attention by a friend, how thick am i. |
If i were a bulb gone would it show up on message centre? |
i don't think it would.
Durham4416 Member Since: 10 Dec 2012 Location: Middlesbrough Posts: 248 ![]() ![]() ![]() |
If it is the bulb, chances are its been removed because the light was on before you bought it? |
Many thanks Jay, im a bit nervous of aftermarket servicing, i might get a qoute from main dealer at least they should have all the upto date equipment, Regards Andy . |
I would have a look at some of your local chaps and give them a call first.
spanner Member Since: 05 Jun 2011 Location: uk Posts: 134 ![]() |
You can test all the lamps in the display by I think holding down the right button system check then turn on ignition to position 2 then ok should appear on display then press left trip reset button you then get a list of check items and from memory its test 2 |
There is no bulb in there, it's an LED and there are two possible causes
Thank you guys for help i will now look into it,Regards Andy, Other than this , what a great car, love it. |
Swiftman Member Since: 23 Jan 2013 Location: Midlothian Posts: 128 ![]() ![]() ![]() |
Hi I have the same problem with my 2006 vogue only had ita couple of weeks & noticed no lamp on at bulb test , if you find the fault please let us know thanks. |
Hi did you ever find the fault with light ? |
