Home > Technical (L322) > Engine management light/ range rover l322 2005 model TD6
bluetoby131
United Kingdom 2005 Range Rover Vogue Td6 Buckingham Blue
Hi to one and all out there, its my first time on this site, My problem is when you put key in ign position two you should have engine management light on and when you start engine it should go out if alls well, mine does not come on at all, car is running perfectly with no faults shown on message centre, i have owned car for one year, and not had any problems, but does anyone have any ideas, or does it have to be plugged in at a dealers ? thanks in advance for any help.
Post #165012 15th Jan 2013 6:50pm
bulb
Post #165014 15th Jan 2013 6:52pm
JAYBOY
HI
If you have had the car for a year have you had it serviced or is it due for one.
Has the engine light ever worked. 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #165016 15th Jan 2013 6:54pm
bluetoby131
Hi have done oil and filters myself , but i am thinking of having an anuall service by garage soon, there are a couple of aftermarket guys locally, and no light has never worked, i recently had it brought to my attention by a friend, how thick am i.
Post #165023 15th Jan 2013 7:06pm
bluetoby131
If i were a bulb gone would it show up on message centre?
Post #165025 15th Jan 2013 7:08pm
JAYBOY
i don't think it would.
Have it checked when it goes for a service.
One thing i would highly recommend is you are driving a 70k motor and it needs to be serviced as per the recommended service intervals or you are just asking for problems.
i would have mine done every year regardless of the miles you have covered.
Jay Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #165028 15th Jan 2013 7:17pm
Durham4416
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
If it is the bulb, chances are its been removed because the light was on before you bought it?
Post #165031 15th Jan 2013 7:20pm
bluetoby131
Many thanks Jay, im a bit nervous of aftermarket servicing, i might get a qoute from main dealer at least they should have all the upto date equipment, Regards Andy .
Post #165032 15th Jan 2013 7:21pm
JAYBOY
I would have a look at some of your local chaps and give them a call first.
These ones look ok
They have land rover qualified engineers so i would give then a go.
http://www.alservices.co.uk/about/ 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #165040 15th Jan 2013 7:36pm
spanner
You can test all the lamps in the display by I think holding down the right button system check then turn on ignition to position 2 then ok should appear on display then press left trip reset button you then get a list of check items and from memory its test 2
Post #165043 15th Jan 2013 7:42pm
There is no bulb in there, it's an LED and there are two possible causes
1. Someone has taped over the LED to stop it showing a fault
2. There is a break in the circuit between the ECU and the LED causing it not to illuminate
You could try the method spanner has shown above but in my experience it sometimes works and at other times doesn't.
My guess is No. 2.
Post #165049 15th Jan 2013 7:49pm
bluetoby131
Thank you guys for help i will now look into it,Regards Andy, Other than this , what a great car, love it.
Post #165146 16th Jan 2013 11:42am
Swiftman
Scotland 2006 Range Rover Vogue SE Td6 Zermatt Silver
Mil light
Hi I have the same problem with my 2006 vogue only had ita couple of weeks & noticed no lamp on at bulb test , if you find the fault please let us know thanks. Bow down
Post #172711 16th Feb 2013 5:10pm
Swiftman
Engine light
Hi did you ever find the fault with light ?
Post #209095 9th Sep 2013 6:29pm
