Home > In Car Electronics (L322) > Intermittent Sat Nav Fault---- HELP
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
Sounds like a continuity problem in the wiring from unit to head unit, does the display on the screen stay ok ?? One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #165009 15th Jan 2013 7:47pm
Porridge
Ireland 2007 Range Rover Vogue TDV8 Java Black
JohnnyD. I think you are on the right thought pattern there. I'm thinking the same, or possible low voltage to the DVD/SatNav unit. Not sure how to test it or fix it though Embarassed
The Display seems fine. FullFat Porridge
2007 TDV8 Vogue.
2005 VTR 1000 SP2.
2012 Hayabusa.
2006 K1200 GT
1988 ur quattro.
Post #166316 21st Jan 2013 4:55pm
ebajema
As Gary said, have a look at traces of (old) water ingress in the lefthand side rear. On mine the Bluetooth died because of that, for some people more damage results or other units die. MY 2010 5.0 SC Galway green and sand interior!!
Post #166322 21st Jan 2013 5:12pm
ellismorgan
hi just read this thread... my 2007 tdv8 has developed the same fault, said i was in the Irish sea.
i moved it back to right position, then when i tried it a couple of days later ,back at the sea side.
thank god i hung on to my tomtom
look forward to an answer to the problem
do land rover care?
Post #166347 21st Jan 2013 6:17pm
Porridge
I rang Land Rover Customer Service (strangley enough they were all unavailable due to the snow in the UK - Guess they don't drive what they support...lol).
They directed me back to the Irish Distributor (which also owns the Stealership which couldn't diagnose the problem). Got chatting to their LR Tech manager. Has never come across this problem before, but sort of agrees that it may be dampness / water ingress somewhere in the car, but... where to start? Big Cry
I knew there was a reason I liked Citroen 2CVs ! FullFat Porridge
2007 TDV8 Vogue.
2005 VTR 1000 SP2.
2012 Hayabusa.
2006 K1200 GT
1988 ur quattro.
Post #166841 23rd Jan 2013 10:23am
keep the a/c on for a few weeks, the dry air should help if its damp inside.. ... - .- -.
Post #166843 23rd Jan 2013 10:26am
