Home > Technical (L322) > Trans Failsafe Mode Error |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
It's possible, but really only likely if you are moving from high to low / low to high ratios, which by the sound of it you aren't. It could be the transfer box itself, or worse ( ) something in the gearbox.
12th Jan 2013 12:22am |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 |
well i still get it into high and low, ive just took it round th eblock twice, its not until u go fromslow to fast or vice versa if that makes sense
12th Jan 2013 12:31am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 969 |
My picture shows the rotary potentiometer for the transfer box shift motor. I don’t think that anything in your description particularly points to this being the issue in your case. The transmission P-codes are generally not emission related so a ‘universal’ diagnostic kit won’t decipher them correctly. You’re much better with some dedicated diagnostic kit like Testbook/T4.
12th Jan 2013 12:35am |
Do u think im looking at a recon box phil? |
12th Jan 2013 12:49am |
John came up with his snap on verdict today
12th Jan 2013 3:45pm |
If you use Manual mode to set off from rest and then, once you've done the 1-2 upshift, move the selector lever back to 'D' (without increasing the throttle enough to cause it to try to downshift into 1st again) does the transmission then behave correctly in fully automatic mode for the whole period before you next have to stop (or slow down enough to drop back into 1st gear again)?
13th Jan 2013 12:01am |
Ill give that a try in tomorrow, I do believe it to be the first gear and I can see ur going in that route
13th Jan 2013 12:54am |
To be honest I was more thinking that it would be best to rule out the 1st gear sprag unit first – especially as you mentioned a ‘slipping fan belt noise’ when you engaged ‘D’.
13th Jan 2013 2:53pm |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 |
Its like it has a high stall converter fitted, there is a big slip then it locks with a bang, on a simpler box I would describe it as low on fluid or blocked filter. One day your life will flash before your eyes......................................make sure yours is worth watching!
13th Jan 2013 3:07pm |
Okay, and does it pull away perfectly if Manual 1st is selected rather than 'D' or is the same problem there?
13th Jan 2013 3:53pm |
It's brilliant in manual 1st and 2nd 3rd etc
13th Jan 2013 4:48pm |
I've been told that the radiator can rust out causing water to get into the gearbox and cause these sort of symptoms is this true?? |
13th Jan 2013 4:56pm |
If that had happened the fluid would look like a pink cream. One day your life will flash before your eyes......................................make sure yours is worth watching!
13th Jan 2013 5:38pm |
Might b worth crawling underneath tomorrow and opening the fluid plug up and taking a peak |
13th Jan 2013 6:59pm |
