Home > General > Odd noises |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6362 |
I know I am a perfectionist but I have noticed a few things about the TDV8 that I didn't have in the TD6, they MAY be faults or they may just be results of a different build.
9th Apr 2010 10:38am |
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 |
I have a similar set of noises coming from the dash area - I have presumed it's all to do with the vents opening up as the engine has become warm enough to circulate air into the cabin. May be totally wrong though.
9th Apr 2010 11:32am |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 |
That would drive me crazy. Take it back! I won't let my Dad ride in the Defender because he is heavy and the passenger seat frame creaks all the time... |
9th Apr 2010 2:18pm |
Shaun the Sheep Member Since: 21 Mar 2010 Location: Bolton, Lancashire Posts: 48 |
I to have an annoying noise from the front passenger seat, it's not there all the time and it seems to be intergrated into the speedometer and since being installed it also added speed camera warnings into the sat nav, and also added shoe shops as points of interest! |
9th Apr 2010 2:45pm |
That's just reminded me of another noise I get, or rather, a noise that only happens when my mate sits on the car. He's the same build as me (slim) but when sits in either the driver or passenger seat the seat belt anchor rubberised part rubs and squeaks on the seat leather. No one else can make it happen! He's jinxed Discovery 4 HSE
9th Apr 2010 5:15pm |
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 410 |
Maybe they're all the same...
9th Apr 2010 11:36pm |
RRCanuck Member Since: 23 Dec 2009 Location: Ontario Posts: 172 |
Same here with the creaking dash RRUK. I've put it down temp change. Usually I will give the dash a firm push just above the speedo before I drive off. Seems to help. Had a BMW that did the same thing.
10th Apr 2010 1:01am |
shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 500 |
RRUK - I know you've changed your car to the bad bomber but did you ever get the issue above sorted. Mines doing the same and it's driving me insane even though I've told the dealers twice about it with no result. They wouldn't take the bigger souce of constant noise that sits there either, not covered under warranty apparently!! MY11 Vogue 4.4 TDV8 - "African Queen" |
4th Nov 2013 6:01am |
fairwx Member Since: 10 Nov 2011 Location: bristol Posts: 124 |
The creaking is indeed the vent motors inside the HVAC - my dealer sorted this by replacing them while fixing a vibration from one other motor.
4th Nov 2013 9:19am |
Blimey, this was SOME time ago!
4th Nov 2013 10:36am |
@RRUK - thanks for the info and pointing out a potential LTB, will mention it to the new dealer I plan to use.
4th Nov 2013 11:39am |
