Home > Maintenance & Mods (L322) > Egr valve, fix bumper and lost a spanner!
Durham4416
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
I got an early finish today so I thought I would whip my front bumper off to realign it as it had dropped by about 1cm on the drivers side, that didn't take to long so I thought I would clean the egr valve as iv had problems in the past with them on other cars, it was properly crudded up so gave it a good clean and re-fitted it, iv seen blanking kits on eBay but £40 seems a bit expensive, in the past I have just blocked them off using a bit of 3mm stainless steel, is this not an option on the range rover? Anyway started taking my tools off the scuttle panel and iv dropped an 8mm spanner and can't for the life of me find it, iv had a light and a magnet and can't see it at all, it's not in the undertray so I'm a bit worried, the wife went and did the school run and all seems ok, hopefully it will just fall out on a bumpy road, not sure what else I can do!
Post #163054 9th Jan 2013 4:38pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
I thought I'd lost one of my sockets in my Discovery engine bay, worried about it for about a day, then forgot. Six months later I was lying under the engine about to tighten up the exhaust downpipes ... guess what I found *STILL* attached .. yep, my socket! It hadn't fallen off the nut it was last used to tighten and gravity obviously mis-functioned Laughing Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #163056 9th Jan 2013 4:45pm
OOh yes could be nasty if it came out on a Motorway.
Might be worth getting it up on a ramp...
Post #163057 9th Jan 2013 4:46pm
what Gary said or stick it in off road and crawl underneath...you should see it with a torch .. ... - .- -.
Post #163059 9th Jan 2013 4:48pm
Durham4416
I put it in off road height and took the bolts out for the undertray but couldn't get it right off, I really haven't a clue where it is, I'm normally quite good at finding bits I drop as I'm a master at dropping stuff, iv used a torch but no joy, I'm worried it may cause some damage, iv checked around the belts and its not there and like you mention if it comes out at 70mph that won't be good, I'll have to take another look tomorrow
Post #163065 9th Jan 2013 5:06pm
Local roads & speedhumps may help!
Post #163066 9th Jan 2013 5:10pm
With regard to the egr.
If when you cleaned it out did you notice if the valve was fully closed to the exhaust gas inlet.
If it was no need to blank off anything, just remove the small vacuum hose so that the valve doesn't operate.
The valve will then stay closed to the exhaust gas inlet and effectively blanks the exhaust gases from entering the inlet manifold.
Post #163089 9th Jan 2013 6:34pm
Durham4416
An right thanks for that, think iv got bigger problems now though, just put a new post up about smoke coming from the filler cap so now I'm really worried the engines gone bad Sad
Post #163094 9th Jan 2013 6:42pm
ahebron
New Zealand
Sorry to hear about your engine issue.
But back to initial issues if you look into the EGR you will see a large amount of the hole is blocked by the valve, this must hinder airflow.
And regarding your lost spanner I misplaced an 11mm socket when working on my 405 diesel early this century. I couldnt find it so gave up and carried on with life. A week later it turned up inside the diff but before ending up there it started off inside the bellhousing and was then picked up by the flywheel and fired through the wall of the bellhousing into the diff which then pushed its spider gear pin into the gearbox housing.
I still have the 11mm socket but its a bit misshapen.
I had the gearbox and diff welded up and flushed the gearset many many times. That car kept going well till my brother inlaw who bought it off me wrote it off.
Adrian VW Amarok 2014 Highline auto
Post #163246 10th Jan 2013 5:27am
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
I found a rusty spanner in my rear bumper a few weeks back. Was a nice snap-on one too ...
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #163248 10th Jan 2013 6:53am
I had a weird humm on my e39 bm, thought nothing too much of it, when i was checking something in the engine hole i found an 18" snap on pry bar, not mine. Bonus. There is nothing that can't be fixed with a hammer😜😜
Post #163256 10th Jan 2013 7:45am
Spanner could have fallen into the viscous fan shroud, so nestling at the bottom of the radiator. The shroud not too difficult to loosen/release, but take care as the locating tabs will be quite brittle by now.
Smoky engine - possible oil separator blocked? .
Post #163260 10th Jan 2013 9:02am
Durham4416
Good shout I'll have a look in the housing, it's had the newer vortex style filter fitted according to receipts but in going to take it off and check, just been to the local Indy who said it will be a ventilation issue and unlikely the engine is goosed, hope he is right, it's booked for the 25th to have the air suspension re calibrated anyway so he will take a look
Post #163332 10th Jan 2013 12:32pm
