Home > In Car Electronics (L322) > Would This Reverse Camera Work?
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Guys
Ive been looking for a reverse camera link this one, would this do the trick?
http://www.ebay.co.uk/itm/Rear-View-Revers...3370bc4ea7
Ive got a 04 vogue
thanks
Neil
Post #162786 8th Jan 2013 4:50pm
if the dimensions of the hole are the same then i would say yes... ... - .- -.
Post #162789 8th Jan 2013 4:59pm
klf400
is there an aux input to connect the camera to ? mine is also a 2004 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #162791 8th Jan 2013 5:22pm
not sure if you think thats all you need, if so then you'd be wrong ..
you also need something like this
http://www.tvandnav2go.com/landrover_range...ations.php ... - .- -.
Post #162793 8th Jan 2013 5:29pm
daveo
you will need one of these,to trigger your monitor to av, pin 22 on the tv plug, i think Question
http://www.ebay.co.uk/itm/330533368428?ssP...1423.l2649
http://www.ebay.co.uk/itm/BMW-3-5-X5-Range...51a56800b3
are you planing to put fit in to the original number plate light on the car.. V8 facelift Range Rover Autobiography 22" wheels.
Post #162848 8th Jan 2013 7:54pm
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
No need for all that,
Get camera pinned in the plug and then get a relay
Wired from reverse light to ground out the activation pin
Can't remember numbers of the top of my head
MSG me if you want them guys. RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #164951 15th Jan 2013 4:07pm
