Home > Maintenance & Mods (L322) > Water in the spare wheel well
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
So I went to check my spare wheel well over as I want to sound proof it tomorrow (exhaust is resonating a little) and noticed some leaves and dampness / small pool of water near the compressor. I'm not really sure how this is getting in, and my car has had the plastic bag fix put in around the AV kit.
Is it normal for any water to be in this area? I have had some soggy stuff in the boot, but nothing that I would have thought would create this amount of fluid.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #160309 28th Dec 2012 4:24pm
mjdronfield
Leaves Shocked
Not had personal experience, touch wood and all that, but I believe the usual water access points are the seal at the bottom of the side window, or behind where the rear bumper bolts come through. I think there is a rectangular cap of some sort that I remember from a pic.
Sometimes the rubber seal on the upper tailgate can give issues, but I'd imagine you'd have a damp boot floor carpet as well.
If I were a betting man, I'd say behind the rear bumper if the carpets are dry......
Good luck. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #160310 28th Dec 2012 4:49pm
TheAllSeeingPie
Aaah didn't think about the rear bumper. Well that's knackered anyway after 2 rear end shunts this year. Was waiting till after any snow till I got it sorted. Might have to double check it's not got any gaps in it then ...
Post #160312 28th Dec 2012 4:52pm
Get the garage/insurance to fix it for you. Put the leak down to the shunts. Get them to check the compressor hasn't been underwater. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #160318 28th Dec 2012 5:13pm
TheAllSeeingPie
I would, if I had either been in the car for the first one (happened while the car was in the first one) or if the guy in the second one hadn't driven off ...
Post #160321 28th Dec 2012 5:33pm
Censored Censored Censored Censored [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #160323 28th Dec 2012 6:05pm
mjdronfield
Here is page 2 of a post that discusses an issue regarding behind the rear bumper, but in true internet fashion, the pictures aren't there anymore......
http://www.fullfatrr.com/forum/topic8265.h...p;start=15 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #160324 28th Dec 2012 6:10pm
Dolphinboy
Check your sunroof drain holes. The rear ones come down near the rear boot and if the NRV is stuck, it floods over into a gulley and comes to the back area where your bumpers are bolted on. This then fills up and comes over the lip at the rear of the car (inside where the wheel well is) into the spare wheel well.
Post #160368 29th Dec 2012 1:04am
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
I to have experiencing problems with water in the boot spare wheel but i believe mine is coming in from the drivers side not the passenger side as thats bone dry.
The corner well and inside bumper housing is get water in there but there is no obvious place its coming from, however ive been going through all the posts on here and found about the boot seal causing issues and found this on the upper right hand corner of my boot seal
now when pulling it off i can clearly see that the seal has corroded inside and its had it but looking at the gap would i be right in thinking it could be running down the inside seal of the car to the boot corner causing a leak that i cant find because of how its routing down here is the pic of the gap behind it i found
any input would be great
thanks
Neil
Post #162416 7th Jan 2013 1:06pm
I had exactly the same as you but on the passenger side.
If you notice where you pulled off the tailgate seal the metal flange on which the seal sits is in two pieces side by side. You will see a gap between the two pieces.
Due to the deficient tailgate seal the water gets under the seal and drains thro the gap between the pieces of the flange. The water then tracks between the body panels and appears at the bottom rear of the boot and then drains into the wheel well. The water also runs between the interior D post trim and the D post and drips out into the rear side compartment.
I renewed the tailgate seal and the problem when away.
Given all the rain this year this does seem to be an effective solution, not a drip in the boot since.
Post #162420 7th Jan 2013 1:28pm
cliffy
Quality stuff, ill order one up now
Post #162473 7th Jan 2013 3:06pm
cliffy
ive sourced a seal which im gonna go and get and fit tomorrow
for tonight ive took all the bits out talc powdered the inside of the section to see exactly where its coming from
Im confident it is the seal and not the bumper beam supports as i had a thurle tow bar fitted a year ago and there is some heavy duty rubber gaskets between the bar and the car
fingers crossed and ill post my results in the morning
thanks
neil
Post #162479 7th Jan 2013 4:04pm
Fill the gap between the two flanges with silicone ? .
Post #162530 7th Jan 2013 6:05pm
cliffy
Joe u read my mind after I've left it tonight out of being curious I want to see where it's coming from then ill b sealing it up lol
Post #162533 7th Jan 2013 6:07pm
cliffy
solved all gone with a new seal
Post #163366 10th Jan 2013 3:12pm
