![]() | Home > Maintenance & Mods (L322) > 06MY on, adaptive cruise control retrofit.. |
I know |
Erm Will, I think you mean exerting ![]() ![]() OK, as regard whether or not it fits, the main pointer will be what exists in the CCF file. If the option is there then there is a chance. Most of the ECUs and electronic stuff on post 06 FFRRs are Ford based and this includes HDC which is probably the most critical one. Remember that HDC was available on Disco-2 way back before BMW even got involved. It's the bit which actuates the brakes, or at least, it is on the Sport, and indeed was the same on my old Merc E500. First things first though, we need to see an example of a CCF file from a FFRR 06-09 model. Unless it's an option there's pretty much zero hope. As regards the functionality, it's nice to have but does have some challenges. Doesn't like heavy spray on the motorway, it's a nuisance if you get some jerk pull into your braking gap as so often happens these days and it is not too good on A roads with traffic coming towards you, albeit on the other side of the road. Speaking personally I much prefer normal CC. Now, if there was a way to have it but revert back to normal CC by turning off ACC then that would be of interest. |
IIRC on the 2011 SSRR I had it can be turned off and normal CC used. As I cover a few miles now it would be nice as I tend to pootle on the inside lane behind the arctics so acc would be nice.
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2593 ![]() ![]() |
Good luck with your insurers when you plough through the back of a Corsa on the motorway. |
If i ploughed into the back of a corsa insurer problems would be least of my problems...
richorus Member Since: 24 Nov 2013 Location: HONG KONG Posts: 4 ![]() |
Has anyone got this done? I just bought a Vogue 5.0, and it didnt come with the ACC, and I want this badly. Anyone? |
