Home > Technical (L322) > Help!
Andy
Help!
Found the battery flat this morning. Not overly concerned as I'm not going out for a few days, but for some reason, the alarm is going off now and I can't disarm it! All the neighbours curtains are twitching!
I can't even get into the garage or the boot to get a spanner to disconnect the battery. What's causing the alarm to sound?
Post #162104 5th Jan 2013 10:12pm
The battery has a back up battery built in and this will be causing the siren to sound. Not sure if the problem is caused by low voltage in the main battery or if water ingress or a fault in the circuit board of the alarm
Post #162124 5th Jan 2013 10:58pm
mjdronfield
did this not happen to someone last year ?
sorry cant post links as using PS3....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #162126 5th Jan 2013 11:02pm
Noddy see here:
http://www.fullfatrr.com/forum/topic10994....rm+battery
Also try search with following criteria, throws up a few more:
+alarm +battery
Post #162130 5th Jan 2013 11:16pm
Andy
Its stopped now thank God. Not sure what has flattened the battery though - its a new 110aH Bosch and has never done this.
Edit: 0100- going off again! Just found a spanner and disconnected the battery but it carried on until it stopped. Hasn't restarted yet, fingers crossed.
Post #162141 6th Jan 2013 12:33am
