![]() | Home > Technical (L322) > TPMS Sensor |
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 ![]() ![]() |
Hey folks, I think the sensor in my spare tyre has definitely broken therefore I need to replace it |
Don't see why not its on the same frequency ====================================
You think? or Definitely? Different things.
Best listen to Dom I just thought they were all the same ====================================
OK, the IID Tool is the one from site sponsor GAP Diagnostics
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 ![]() ![]() ![]() |
I've got a couple of genuine sensors without the valve stems (background: tyre fitter broke the stems when changing tyre, I didn't want to faff about with reprogramming new ones, so I swapped the stems over).
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
The land rover tech was nearly right, the receiver for all the tyres is in the panel above the mirror, the 4 initiators in the wheel wells send a signal to each wheel to get the sensor to send TPMS information. Your spare tyre needs to be pumped up to 42 psi (maximum recomended tyre pressure) to keep the 'check spare tyre' message away. If you do change the spare tyre sensor, you will need to get the sensor programmed to the car or run the wheel on one of the axles for approx 15 miles (in one run) to program the sensor to the vehicle 56 TDV8 Vogue SE 9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled) 91 Lotus Carlton (sold) 90 Lotus Elan (BRG) |
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 ![]() ![]() ![]() |
I bought a set of 5 from this seller to put on my 'winter wheels' - worked fine and all other than the spare have auto reset themselves |
Hi I've pumped the tyre up past 42 psi to make sure it was above the amount to trigger the alarm this hasn't worked as i said in a previous post |
New sensor then or IID tool to switch the system off.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
TPMS is such a crock of |
Not all VSE's come with it , it doesn't have it on mine 2010 Mdl ====================================
YAY! There is hope yet!
Hate it myself. When I first read about I thought it sounded great but its just another thing to go baps up! |
