Home > Maintenance & Mods (L322) > Poly bushes?
stuboy00
Scotland 2006 Range Rover Vogue SE Td6 Java Black
Poly bushes?
Hi guys so i put the rover in to get the tracking reset and was told that there is some wear in some of the rear bushes so my question is does anybody know if I can get poly bushes to upgrade the original ones I'm looking to replace all front and rear?
Cheers stu F**K IT you only live once
Post #161473 3rd Jan 2013 10:21am
Best stick with original bushes Thumbs Up
Post #161474 3rd Jan 2013 10:22am
stuboy00
Embarassed Kind of thought that but it was worth a try Whistle where is the best place to get the part numbers for front and rear bushes should I prepare myself Big Cry Laughing F**K IT you only live once
Post #161480 3rd Jan 2013 10:31am
Check with Dan Thumbs Up ====================================
Post #161483 3rd Jan 2013 11:00am
BrianC
My Experiance with poly bushes is they will wear the arms out
Post #161486 3rd Jan 2013 11:11am
Poly bushes give a harsher ride and are slightly easier to fit, but since you have to to remove the old bushes first which is the hardest part you are best keeping to OE
Post #161488 3rd Jan 2013 11:13am
stuboy00
Yea! That's really surprising? I mean I know there big old lumps but I've never seen that before ( used to use poly bushes in my show car days ) had a Clio lowered 300mm custom springs poly bushes the lot had everything seam welded because the suspension was solid Rolling with laughter F**K IT you only live once
Post #161493 3rd Jan 2013 11:17am
mzplcg
http://www.polybush.co.uk/shop/view/713_Ra...(Series_3)
I fitted some to my old D3 and it was no more harsh than standard bushes. Not exactly cheap though.
Post #161498 3rd Jan 2013 11:29am
It can be a contentious debate on Defender forums. I've always stuck with Genuine because they're the most hassle-free product. They do the job and do it very well.
On a FF, I would imagine its even more clearer cut. I've always found that one modification invariably requires another to make it work or look correctly.
I know many seasoned Defender experts who wouldn't use Polybushes but really rate Superpro for quality, feel and longevity. If, but only if, a change of bush material was required, that's what I'd most likely be fitting. Si. <This is my name.
Post #161513 3rd Jan 2013 12:33pm
Ive polybushed several including my rear wishbones and i think they are great and certainly no more uncomfortable than standard bushes in the FF or D3...
Craig Thumbs Up
Post #161538 3rd Jan 2013 12:48pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I agree, had them fitted to a Defender, basically "fitted for life", never replaced them in 10 years of ownership and some pretty heavy off roading.
Post #161542 3rd Jan 2013 12:51pm
barracuda816
United Kingdom 2005 Range Rover Vogue SE Td6 Tonga Green
The only thing i can say is the superpro bushes are much better.
The material doesn't really differ in quality but Its very important to use stainless inserts AND bolts (or use plenty of copper grease on the bolts) as polyurethane doesn't "flex" as much as rubber and relies on the inserts/sleeves to rotate a little.
So as soon as the inserts/sleeves start to corrode and seize the actual bush material will wear in no time. (i have seen in plenty on pollybush ones)
I personaly only really would bother if i couldnt get hold of decent original bushes. Like on many of my classics, where the repro ones have been utter ****.
Just my two pence worth. Thumbs Up
Post #161604 3rd Jan 2013 4:34pm
mzplcg
Unless anyone knows different Superpro aren't available for the L322 though, only Polybush or OEM.
Post #161644 3rd Jan 2013 7:03pm
