![]() | Home > Maintenance & Mods (L322) > Poly bushes? |
stuboy00 Member Since: 09 Feb 2012 Location: Glasgow Posts: 251 ![]() ![]() ![]() |
Hi guys so i put the rover in to get the tracking reset and was told that there is some wear in some of the rear bushes so my question is does anybody know if I can get poly bushes to upgrade the original ones I'm looking to replace all front and rear?
Best stick with original bushes |
Check with Dan |
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 ![]() ![]() |
My Experiance with poly bushes is they will wear the arms out |
Yea! That's really surprising? I mean I know there big old lumps but I've never seen that before ( used to use poly bushes in my show car days ) had a Clio lowered 300mm custom springs poly bushes the lot had everything seam welded because the suspension was solid |
http://www.polybush.co.uk/shop/view/713_Ra...(Series_3)
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
It can be a contentious debate on Defender forums. I've always stuck with Genuine because they're the most hassle-free product. They do the job and do it very well.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Ive polybushed several including my rear wishbones and i think they are great and certainly no more uncomfortable than standard bushes in the FF or D3...
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
I agree, had them fitted to a Defender, basically "fitted for life", never replaced them in 10 years of ownership and some pretty heavy off roading. |
barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213 ![]() ![]() ![]() |
The only thing i can say is the superpro bushes are much better.
Unless anyone knows different Superpro aren't available for the L322 though, only Polybush or OEM. |
