Home > Technical (L322) > Injector test ?
lrdaft
Scotland 2011 Range Rover Vogue TDV8 Santorini Black
Easy way to test is to remove spill pipe and clamp off then switch on ignition and see if any diesel comes up from any injectors if any diesel comes up its faulty simples Whistle 2011 4.4tdv8 vogue black with black
2005 autobiography supercharged in Auckland blue!
2005 supercharged now sold
2011evoque now sold
2007 tdv8 vogue se gone but not forgotten
rrsport 2.7 hse gone
4.4 autobiography 2004
Post #161344 2nd Jan 2013 5:02pm
Did you get this sorted W88DY?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #170650 7th Feb 2013 8:54am
W88DY M
United Kingdom 2003 Range Rover Vogue Td6 Oslo Blue
Yes mate it was a faulty injector. I got a new one and changed it. Everything is fine now
Thanks mark Thumbs Up
Post #170663 7th Feb 2013 10:16am
Cheers fella. Did you DIY or indy it? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #170683 7th Feb 2013 12:21pm
W88DY M
Diy mate. Indy wanted close to £500 incase anything went wrong Evil or Very Mad Took me about 1 1/2 hours to do with no probs. cost. £105 all in happy days Thumbs Up
Post #170690 7th Feb 2013 12:37pm
Excellent news that Smile Was that recon of the unit you took off or a new recon/new unit?
I'll do a leak off test when the covers are off and replacing the leak off pipes anyway, not sure i have enough plastic bottles left so will do 2 at a time and time them for 30seconds Smile
I understand that some injectors are hard to get out as well from youtube vids i've seen so will be doing the citroen HDi method if i need to of soaking the hell out of them with wd40 or penetrating fluid, getting the engine nice and warm and then applying an ice cube to the top to shrink it/them if they are sticky feckas Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #170691 7th Feb 2013 12:42pm
W88DY M
It was a new recon one off the shelf. Mine came out with a little help of a large screwdriver and just came out Mr. Green Hope yours come out just as easy Thumbs Up
Post #170695 7th Feb 2013 12:46pm
Can I ask how you tested it and did you get one of those special 17mm sockets to get it out? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #170699 7th Feb 2013 1:16pm
W88DY M
All I used was a socket set and Allen keys. I just took the leak off tubes off clamped the end off. And turned on the ignition on if they are faulty they should leak out the top Thumbs Up
Post #170702 7th Feb 2013 1:23pm
Cool, fingers crossed it will work.
I'll stick an old rag round the back of the injectors during the test as knowing my luck one will be leaking like a sieve Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #170706 7th Feb 2013 2:07pm
