Home > Technical (L322) > Injector test ?
W88DY M
United Kingdom 2003 Range Rover Vogue Td6 Oslo Blue
Injector test ?
Sorry if this has been on here before, but is there a way
To check if you injectors are working without removing them.
My td6 is taking longer to star. Its had new battery, new secondry fuel pump and
new glow plugs. I think it might be the injectors at fault
Thanks for any info
Mark
Post #161102 1st Jan 2013 10:30pm
When it does start, does it tick over smoothly? Does it run smoothly when driving? Previously..
Post #161104 1st Jan 2013 10:33pm
W88DY M
Yes it's fine when it's started. And it starts ok after that, its just when you first start
It. It doesn't mater if its warm or cold outside
Thanks mark
Post #161106 1st Jan 2013 10:39pm
Have you checked the fuel lines, sounds like it could be leaking back towards the tank due to an air leak at a joint
Post #161110 1st Jan 2013 10:41pm
W88DY M
I haven't checked for a air leak. I don't know where to
start to look for it, any ideas where to look Thumbs Up
Post #161115 1st Jan 2013 10:46pm
Start at the filter, if you can see air bubbles then you have a leak
Post #161118 1st Jan 2013 10:49pm
W88DY M
Thanks 47p2 ill have a look in the morning and let you's know
Thanks again Thumbs Up
Mark
Post #161120 1st Jan 2013 10:51pm
W88DY M
Ok. I've checked for air in the clear fuel lines but there is no signe of any
Is there a way to check the injectors without removing them
Thanks mark Thumbs Up
Post #161161 2nd Jan 2013 9:24am
You can, there's the leak off test where you attach a tube to each injector and put the other end in a jar. You then start the engine and see which injector fills the jar. That's the dodgy one.
Post #161176 2nd Jan 2013 10:21am
If it runs smoothly, cold or hot, when it does start, what you are saying is you think the injector is faulty but it starts working perfectly when the car starts. I have a problem with that. I think the fault is elsewhere. Previously..
Post #161179 2nd Jan 2013 10:36am
Stuart's the man
2nd that not an injector problem
Post #161180 2nd Jan 2013 10:45am
W88DY M
Oh we'll looks like its going to the Indy again
Thanks for all your help, if I get it sorted ill let
You's know what it was
Thanks again
Mark Thumbs Up
Post #161181 2nd Jan 2013 11:03am
wats39
Scotland 2004 Range Rover SE Td6 Alaska White
Would definately do a leak back test on the injectors. seen this a few times before on common rail diesels including the ffrr. if an injector leaks back too much it stops the fuel pressure building up in the rail as quick which delays the start. when its running the engine speed is fast enough to give enough pressure therefore run ok. dont think the kits are expensive either. either that, you could connect a diagnostics and watch the fuel pressure in the fuel rail building when cranking it over. it should raise pretty quick. the fuel pressure regulator and the fuel pumps could also cause this. among other things no doubt Rolling Eyes but would try a leak back first then you can rule the injectors out if ok. '04 td6 se
'63 land rover s2 200tdi
'04 mk indy kitcar bike engine
Post #161187 2nd Jan 2013 11:21am
W88DY M
Will do mate thanks Thumbs Up
Mark
Post #161191 2nd Jan 2013 11:26am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Worth checking that the new glowplugs are working too.
Post #161323 2nd Jan 2013 4:35pm
