![]() | Home > Technical (L322) > Injector test ? |
W88DY M Member Since: 15 Sep 2011 Location: liverpool Posts: 116 ![]() ![]() ![]() |
Sorry if this has been on here before, but is there a way
Yes it's fine when it's started. And it starts ok after that, its just when you first start
Have you checked the fuel lines, sounds like it could be leaking back towards the tank due to an air leak at a joint |
I haven't checked for a air leak. I don't know where to
Start at the filter, if you can see air bubbles then you have a leak |
Thanks 47p2 ill have a look in the morning and let you's know
Ok. I've checked for air in the clear fuel lines but there is no signe of any
You can, there's the leak off test where you attach a tube to each injector and put the other end in a jar. You then start the engine and see which injector fills the jar. That's the dodgy one. |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
If it runs smoothly, cold or hot, when it does start, what you are saying is you think the injector is faulty but it starts working perfectly when the car starts. I have a problem with that. I think the fault is elsewhere. Previously..
Stuart's the man Member Since: 16 May 2012 Location: Glasgow Posts: 94 ![]() |
2nd that not an injector problem |
Oh we'll looks like its going to the Indy again
wats39 Member Since: 08 Jul 2012 Location: fife Posts: 77 ![]() ![]() ![]() |
Would definately do a leak back test on the injectors. seen this a few times before on common rail diesels including the ffrr. if an injector leaks back too much it stops the fuel pressure building up in the rail as quick which delays the start. when its running the engine speed is fast enough to give enough pressure therefore run ok. dont think the kits are expensive either. either that, you could connect a diagnostics and watch the fuel pressure in the fuel rail building when cranking it over. it should raise pretty quick. the fuel pressure regulator and the fuel pumps could also cause this. among other things no doubt |
Will do mate thanks |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Worth checking that the new glowplugs are working too. |
