![]() | Home > Wheels & Tyres > range rover tdv8 vogue tyre pressure |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
It's on the sticker inside the door shut of the drivers door, use your eyes! |
mbdj Member Since: 14 Jul 2010 Location: scotland Posts: 98 ![]() ![]() ![]() |
thanks for your quick reply will check thanks. |
However......
supermario Member Since: 27 Oct 2011 Location: UK Posts: 55 ![]() ![]() |
Whats the reason for having lower pressure on the front? Just wondering thanks |
Bomber County Member Since: 12 Dec 2011 Location: Dunston, Lincoln Posts: 81 ![]() ![]() ![]() |
for what it's worth I was told by someone on the forum that 36 front and 42 rear was the best pressure for my TDV8 on 19's.
There is only 1 way to find out the correct pressure for your tyres in your typical use and thats the chalk method... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Lower pressure on the front as the weight over the front axle doesn't change with load where as the rear has a full tank of fuel sometimes, full boot and pulling a large load which could exert upto 150kg weight extra.
TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester/Abu Dhabi Posts: 206 ![]() ![]() ![]() |
I increased mine to the full load and gained 3 mpg
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
makes sense...more pressure will give you less rolling resistance and therefore slightly more mpg.. ... - .- -.
