Home > General > Rain sensing wipers |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 |
I have just been out for a sort drive, not that it makes any difference to the problem.
31st Dec 2012 2:46pm |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 |
Same on mine. Wipers have to be turned off and then on again to activate. I think its to stop people driving in to car washes not realising that the wipers are on! 2012 5.0L S/C
31st Dec 2012 2:49pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Normal operation, annoying, but normal .
31st Dec 2012 3:09pm |
IIRC its to make sure that they dont kick on when first turning the ignition on incase the screen is frozen.
31st Dec 2012 3:16pm |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
IIRC mine do the same but can be kicked into life by changing the sensitivity rocker by 1 click. |
31st Dec 2012 3:35pm |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
Exactly the same here in my '02. I too find it annoying as the auto wipers on my E55 stay on auto all the time.
31st Dec 2012 3:44pm |
I complained about this a while ago on a thread, which resulted in me realising that I'd be even more annoyed if it tried to automatically wipe when the wipers were frozen to the screen, so I changed my mind and decided that it was better how it actually operated.........
31st Dec 2012 4:47pm |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 922 |
On my 11MY they are constantly on if the stalk is in the auto position. |
1st Jan 2013 8:09am |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 800 |
same here |
1st Jan 2013 11:50am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Normal on a FF but work always on a D3! Don't figure!
1st Jan 2013 12:18pm |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
If I remember rightly the D3/Sport are almost completely Ford designed whereas the FFRR is BMW based but then moved over to Ford components (facelift = ran out of BMW seats). So the wiper systems seem to work in the same way as a BMW or Ford do. BMW are sensible and don't want to tear your wipers off if the weather is cold (sensible German logic), whereas Ford are lazy and keep the wipers on in case you forget (typical American logic).
1st Jan 2013 12:44pm |
BMW automatic wipers are always by means of a button on the end of the right stalk. When pressed once, you get an initial wipe and an illuminated green light. When the ignition is stopped/if the stalk is pressed again, automatic stops.
1st Jan 2013 2:34pm |
You don't, just change the sensitivity rocker .... its less clumsy than moving the stick about. |
1st Jan 2013 3:08pm |
Rolo Member Since: 11 May 2011 Location: UK Posts: 852 |
must have changed on the later models as mine stay on auto & work again next time without turning on/off again. |
8th Jan 2013 5:51pm |
