![]() | Home > General > Rain sensing wipers |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
I have just been out for a sort drive, not that it makes any difference to the problem.
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
Same on mine. Wipers have to be turned off and then on again to activate. I think its to stop people driving in to car washes not realising that the wipers are on! |
Normal operation, annoying, but normal .
IIRC its to make sure that they dont kick on when first turning the ignition on incase the screen is frozen.
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
IIRC mine do the same but can be kicked into life by changing the sensitivity rocker by 1 click. |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Exactly the same here in my '02. I too find it annoying as the auto wipers on my E55 stay on auto all the time.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
I complained about this a while ago on a thread, which resulted in me realising that I'd be even more annoyed if it tried to automatically wipe when the wipers were frozen to the screen, so I changed my mind and decided that it was better how it actually operated.........
Autobiography Member Since: 10 May 2011 Location: UK Posts: 925 ![]() ![]() |
On my 11MY they are constantly on if the stalk is in the auto position. |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 816 ![]() ![]() |
same here |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Normal on a FF but work always on a D3! Don't figure!
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
If I remember rightly the D3/Sport are almost completely Ford designed whereas the FFRR is BMW based but then moved over to Ford components (facelift = ran out of BMW seats). So the wiper systems seem to work in the same way as a BMW or Ford do. BMW are sensible and don't want to tear your wipers off if the weather is cold (sensible German logic), whereas Ford are lazy and keep the wipers on in case you forget (typical American logic). |
BMW automatic wipers are always by means of a button on the end of the right stalk. When pressed once, you get an initial wipe and an illuminated green light. When the ignition is stopped/if the stalk is pressed again, automatic stops.
You don't, just change the sensitivity rocker .... its less clumsy than moving the stick about. |
Rolo Member Since: 11 May 2011 Location: UK Posts: 852 ![]() ![]() ![]() |
must have changed on the later models as mine stay on auto & work again next time without turning on/off again. |
