Home > Technical (L322) > no drive in reverse.... |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
Check the wiki for the gear selector cable article. If that doesn't fix it you might be in the Sales Of Goods Act territory with whoever you bought it from.
30th Dec 2012 1:05pm |
bigee Member Since: 23 Nov 2012 Location: wales Posts: 58 |
Thanks for the reply...just looked at the Wiki,fingers crossed
30th Dec 2012 1:28pm |
Tis done....selector seems a bit slicker? Will see over the next couple of days..Thanks for the heads up |
30th Dec 2012 3:50pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
Now you have it free with WD 40 give it a good coat of grease to protect and lubricate for the future.
30th Dec 2012 4:04pm |
noted and done.....every other forum where a question is asked re: FF this is the default answer given.....i can see why |
30th Dec 2012 4:11pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 963 |
Which model is your L322?
30th Dec 2012 4:49pm |
Phil, its a 2002 4.4 v8......pics to come shortly(when i can stop driving it for long enough to take some ) |
30th Dec 2012 5:00pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8512 |
funnily enough it has just occurred to me that i used to have exactly that problem with a E61 BMW, it was like it had to think about engaging reverse, and you could rev it in R to no avail, then it would engage, i wonder if this was a similar related problem.
30th Dec 2012 7:45pm |
did you ever get to the bottom of it? |
30th Dec 2012 8:52pm |
No, choped it in for the ff. There is nothing that can't be fixed with a hammer😜😜
30th Dec 2012 8:58pm |
..Twas a good move...... Funny enough i 'got out' of my Cayenne Turbo because of impending box problems so really hoping this is something minor....part of the attraction for choosing this particular vehicle was the low (relatively) mileage @73k and a recent box rebuild....thought i had covered my bases
30th Dec 2012 9:04pm |
Losing reverse isn’t that common with the later 5HP24s. I’ve never seen an F-clutch piston seal wear problem (which plagued the early BMW/Jaguar versions) on an L322 :
30th Dec 2012 11:20pm |
Fantastic, i will (fingers firmly crossed ) see over the next day or so if it was merely the linkage...if not,then i will have to find a decent indi (forum member??) as my mechanical knowledge is somewhat limited!!
31st Dec 2012 8:12am |
greatw Member Since: 06 Aug 2012 Location: Up North Posts: 21 |
I'll watch this one with interest!.
31st Dec 2012 11:37am |
