![]() | Home > Maintenance & Mods (L322) > Soundproofed my boot (part 1) |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
I decided to put some sound proofing down in my boot as there seems to be a resonance coming from there, probably due to the new exhaust, that wasn't there before. It was actually quite a simple job, even though it appears Halfords don't check their exchanges properly and sold me a roll of soundproofing that was missing a 4x18" section. Fortunately I had calculated that I would have had spare and I'd already unbolted the compressor at this point.
Then I started working through the wheel well looking for areas that seemed especially resonant to a light tap with a spanner. I covered these using some Vibe Anti-Vibe Sound Deadening Material, which is kinda like Dynamat but cheaper.
I then went around again and found a couple of places that now sounded the most resonant and covered those. Eventually I had covered enough that almost everywhere was much more dampened than when I had started. Here's the final result:
You don't have to completely cover the whole boot with the stuff as it's there to reduce panel vibration which causes resonance. When my 12mm thick acoustic foam arrives (it should have been here today), I'll be covering everything over with that to completely deaden any noise being transmitted through the wheel well. A little test drive afterwards confirmed it was definitely quieter inside the car now, and it was definitely worth the 2 hours it took to fit and the �50 of materials to do it. I've just got to adjust the resonance chambers on my exhaust to tune out a mild 2k rpm drone and my car will be quieter than when it had a stock exhaust while cruising, and fecking noisy when I want it to be. 07 Supercharged - Still breaking her in! Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html 18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html |
Mine already has that factory fitted |
Iirc roofing felt is much cheaper and does te same job but is a bit heavier and not as shiny |
I used to cut pieces of Code 6 lead sheet and glue them in place with builders adhesive. Lot cheaper than Halfords and very effective. |
Flashing tape / roofing felt is bitchumen based, the butyl stuff is nearly the same price per square metre as the Vibe stuff. Not heard of the lead stuff but it gets hot in there and I'd not be happy about a boot full of lead. Also the boot gets quite warm now so wanted something I know would stick and not stink.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8739 ![]() ![]() ![]() |
Not with the price of lead nowadays, unless its "holy lead" of course |
You don't need much lead for it to be effective.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6418 ![]() ![]() |
Ah, but LR didn't count on the AllSeeingPie fitting the "loudest" exhaust system he could come up with |
Just because I had the resonators removed on a straight through exhaust doesn't mean it's the loudest I could come up with ... oh er yeah I get your point! In fact I got told off by SWMBO earlier for driving "loudly" and she was 1/4 mile away in Cafe Nero!
I think for a tunes exhaust yours won't be that bad as its still got the cats in it |
The cats are 100 cell sports cats, so are roughly 1/5th the size of the LR ones and flow a lot better |
Cats are for pussy's! |
New MOT regs state that a cat must be visibly fitted from 2012 onwards hence the teeny tiny ones fitted. Also it being a 4.2 litre supercharged motor there's no chance of it passing an MOT without cats. |
Some petrols AFTER 92/k reg can pass an MOT easily without breaking any regs and without a cat fitted |
