Home > Technical (L322) > Engine light and judder |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 |
When the engine light can on did the car go into limp mode. 2020 Porsche Panamera Turbo Hybrid (V FAST)
23rd Dec 2012 9:04pm |
supermario Member Since: 27 Oct 2011 Location: UK Posts: 55 |
It did not say anything I pressed the dash button and it said check system ok - I think it was not in limp home mode does it say anything like that? |
23rd Dec 2012 9:10pm |
Took it out again - seems to be when I ever I put my foot to the floor or try to accelerate more than ver gradual it stutters maybe a fuel filter thing? I just had it serviced from or Edinburgh last month so a bit suprised will try to get t to dealer tomorrow check out |
23rd Dec 2012 10:29pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
Maybe injectors |
23rd Dec 2012 10:45pm |
Ok Does the car move up in speed slowly without the shudder. If so what does it do if you floor it from standing start. Make sure its warm before you try the floor it bit. 2020 Porsche Panamera Turbo Hybrid (V FAST) 2017 Range Rover Autobiography 5.0 V8 2018 JCW Mini Cooper 2018 Skoda VRS |
23rd Dec 2012 10:54pm |
Thanks guys - yep if I accelerate slowly from still or any speed it seems fine maybe slightly judderey. From standing start flooring it judders a fair bit but has spells where it is smooth ish. Essentially though light acceleration much less judder |
24th Dec 2012 8:03am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35271 |
sounds like a fuel starvation problem due to blocked injectors or pump maybe....cheapest 1st port of call could be sticking some injector cleaner in the tank to see if that helps... ... - .- -.
24th Dec 2012 8:06am |
Thanks guys I may take the trip from manc to London see how it goes... |
24th Dec 2012 8:59am |
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 |
defo try some injector or fuel system cleaner in a tank of fuel and go from there |
24th Dec 2012 9:49am |
Cool thanks-should I not be too worried about the engine light. It's still on but the car was going up and beyond 80 last night |
24th Dec 2012 11:00am |
How much fuel is in the tank? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
24th Dec 2012 11:02am |
It's full put some Carlube diesel cleaner in around 3/4 then filled it up |
24th Dec 2012 11:05am |
Hmm. Id be more tempted to say a fuelling issue with the supply and not the delivery...
24th Dec 2012 11:27am |
Well I had a service in Nov it was the 70000 5yr service I think it should of been changed then don't have documentation to hand -will driving it now be ok it should not make it worse its a motorway journey so maybe should clean it out - although the previous journey from Edinburgh was mainly motorway that's why I can't understand. Unless it was some cloggy bad diesel I was using vpower as well - went back to normal on this tank |
24th Dec 2012 11:34am |
