Home > Technical (L322) > Engine light and judder
supermario
Hi guys, any help would be appreciated. I just drove 220 miles yesterday in my 07 3.6tdv8 fine no problems. Today I go for a short drive and the engine light is on the car for the next 10 mins is very judder dry at low speeds I put my foot down and was still judderey. It seemed ok ish after 10 mins light is still on. Don't have access to a fault reader as I am at my folks I need to drive another 200 miles on Christmas Day any ideas? I am going to take it out again just now to see what happens. Thanks in advance
Post #159650 23rd Dec 2012 9:01pm
JAYBOY
When the engine light can on did the car go into limp mode. Question 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #159651 23rd Dec 2012 9:04pm
supermario
It did not say anything I pressed the dash button and it said check system ok - I think it was not in limp home mode does it say anything like that?
Post #159654 23rd Dec 2012 9:10pm
supermario
Took it out again - seems to be when I ever I put my foot to the floor or try to accelerate more than ver gradual it stutters maybe a fuel filter thing? I just had it serviced from or Edinburgh last month so a bit suprised will try to get t to dealer tomorrow check out
Post #159697 23rd Dec 2012 10:29pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Maybe injectors
Post #159714 23rd Dec 2012 10:45pm
JAYBOY
supermario wrote:
Took it out again - seems to be when I ever I put my foot to the floor or try to accelerate more than ver gradual it stutters maybe a fuel filter thing? I just had it serviced from or Edinburgh last month so a bit surprised
Ok
Does the car move up in speed slowly without the shudder.
If so what does it do if you floor it from standing start.
Make sure its warm before you try the floor it bit. 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #159721 23rd Dec 2012 10:54pm
supermario
Thanks guys - yep if I accelerate slowly from still or any speed it seems fine maybe slightly judderey. From standing start flooring it judders a fair bit but has spells where it is smooth ish. Essentially though light acceleration much less judder
Post #159752 24th Dec 2012 8:03am
sounds like a fuel starvation problem due to blocked injectors or pump maybe....cheapest 1st port of call could be sticking some injector cleaner in the tank to see if that helps... ... - .- -.
Post #159753 24th Dec 2012 8:06am
supermario
Thanks guys I may take the trip from manc to London see how it goes...
Post #159760 24th Dec 2012 8:59am
rathbranV8
Ireland 2002 Range Rover SE 4.4 V8 Oslo Blue
defo try some injector or fuel system cleaner in a tank of fuel and go from there
Post #159776 24th Dec 2012 9:49am
supermario
Cool thanks-should I not be too worried about the engine light. It's still on but the car was going up and beyond 80 last night
Post #159788 24th Dec 2012 11:00am
How much fuel is in the tank? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #159789 24th Dec 2012 11:02am
supermario
It's full put some Carlube diesel cleaner in around 3/4 then filled it up
Post #159791 24th Dec 2012 11:05am
Hmm. Id be more tempted to say a fuelling issue with the supply and not the delivery...
When was the fuel filter last changed?
Injectors on diesels tend to fail by leaking and slowly getting worse not failing to open properly but there is always the odd one i guess Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #159793 24th Dec 2012 11:27am
supermario
Well I had a service in Nov it was the 70000 5yr service I think it should of been changed then don't have documentation to hand -will driving it now be ok it should not make it worse its a motorway journey so maybe should clean it out - although the previous journey from Edinburgh was mainly motorway that's why I can't understand. Unless it was some cloggy bad diesel I was using vpower as well - went back to normal on this tank
Post #159795 24th Dec 2012 11:34am
