Home > In Car Electronics (L322) > No GLS listed on Head Unit |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 |
You would need to find someone close to you with the same model FFRR and see if you can try it, what year is the car? A stereo shop may have one you can borrow, does the cartridge eject ok? One day your life will flash before your eyes......................................make sure yours is worth watching!
23rd Dec 2012 2:37pm |
Thats normally when theres a disc stuck inside or not loading from cartridge into player One day your life will flash before your eyes......................................make sure yours is worth watching!
23rd Dec 2012 5:29pm |
Paulhh Member Since: 23 Dec 2012 Location: Carrbridge Posts: 143 |
I'm going out to try right now, I'll go back to just one disc and try it in each slot |
23rd Dec 2012 5:33pm |
see if it loads and stays loaded and turns or loads and gets spat out again. One day your life will flash before your eyes......................................make sure yours is worth watching!
23rd Dec 2012 5:37pm |
When you insert the cartridge but don't slide the cover across, you can see the mechanism selecting each level, all 6 are looked at but you do not see or hear a CD being pulled into the mechanism. Looks or sounds like the mechanism is jamming at that point. |
23rd Dec 2012 5:45pm |
Sounds like something mechanical now, call the repair guys and if they write it off you at least know where there is another thats all working, not fun to remove though !!! One day your life will flash before your eyes......................................make sure yours is worth watching!
23rd Dec 2012 5:52pm |
Cheers for your help, it does sound mechanical I guess.
23rd Dec 2012 5:57pm |
maybe it had a Tracker at sometime that would have a GPS connection, you need to think about a MK4 sat nav as you seem into your gadgets, do a search on here. One day your life will flash before your eyes......................................make sure yours is worth watching!
23rd Dec 2012 6:12pm |
Cheers mate
23rd Dec 2012 6:25pm |
IMO not worth fitting the mp3 changer if you have an Ipod, you will stillneed the intravee and to but an MP3 changer One day your life will flash before your eyes......................................make sure yours is worth watching!
23rd Dec 2012 6:32pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7708 |
Hi Paul,
23rd Dec 2012 8:39pm |
Thanks for that. I have a spare Disco 2 CD cartridge and unit. Tried that cartridge but just the same. It looks like the CD changer isn't grabbing each CD slider, so nothing goes into the actual CD reader. |
23rd Dec 2012 8:54pm |
