Home > In Car Electronics (L322) > Tints causing poor reception.
I was sat outside derby station yesterday waiting for a delayed train, tv on i thought, but the reception was Censored .
I know that the aftermarket tints i have can cause the radio reception to be pants, which it is. Is there any way to get a better tv reception, presumably if i put an additional antenna on the rear glass it will also have pants signal as its behind the tint?
Ideally something in the roof antenna would be good..... Is this possible?
Cheers chapettes. There is nothing that can't be fixed with a hammer😜😜
Post #159478 23rd Dec 2012 9:56am
you're correct in saying that aftermarket tints do cause reception problems thats why you should get carbon based tints which dont have any metal in them...
as for your problem i would firstly check the amp is ok and the connections are sound and clean, if that doesnt help then maybe wire in an aftermarket antenna ..
also, could it be that that location was rubbish for tv reception? ... - .- -.
Post #159495 23rd Dec 2012 11:13am
When i bought it, it had the tints but i was naieve as to all the issues, also whether they were lr or after market.
Now i know, in hind sight i would have chosen a different car, there were a few to choose from.
Will check the connections, is there a separate amp for the antenna? There is nothing that can't be fixed with a hammer😜😜
Post #159523 23rd Dec 2012 1:07pm
from memory i think its a little white box with a smc type connector on it... ... - .- -.
Post #159526 23rd Dec 2012 1:17pm
will have a butchers in the morning, I think I have an idea what it looks like.... There is nothing that can't be fixed with a hammer😜😜
Post #159584 23rd Dec 2012 5:26pm
