Home > Technical (L322) > Rotational related noise
Durham4416
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
When travelling slow on some road surfaces I get a noise like something is stuck on a tyre, sounds like its from the front, anyone had this problem, could it be something to do with the propshaft? It gets faster and slower depending on speed bout once at 25+ mph there's nothing?
Post #159293 22nd Dec 2012 8:05pm
Sorry for the obvious.... But have you checked all the way round the tyre for stuck stones etc?? Does the noise change if you brake? Previously..
Post #159294 22nd Dec 2012 8:07pm
JAYBOY
Can you hear it with the windows shut. 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #159295 22nd Dec 2012 8:07pm
Durham4416
To be honest I havn't tried listening with the windows down, I can feel it through the seat and the floor a little but nothing through the steering wheel, I'll give the tyres a good check over in the light tomorrow, could it be a wheel bearing? Thanks for the quick replies
Post #159297 22nd Dec 2012 8:09pm
Don't worry about bearings, shafts etc until you have thoroughly checked the tyres Thumbs Up Previously..
Post #159298 22nd Dec 2012 8:12pm
Durham4416
Yes I'll give them a good check in the morning and report back, strange how its only at slow speeds, hope its nothing serious
Post #159299 22nd Dec 2012 8:13pm
jack that wheel up and rotate the wheel, this might find the cause.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #159300 22nd Dec 2012 8:15pm
JAYBOY
Have you changed your tyre recently. Question
if you have a spare set then change to them for a couple of days and see if it goes. Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #159301 22nd Dec 2012 8:15pm
Durham4416
I've only had the car about 4 weeks, front tyres are Goodyear wranglers and about half worn, I'll jack it up in the morning and give it a spin and a wobble and see if there's anything obvious
Post #159303 22nd Dec 2012 8:16pm
Lloyd Barnes
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
I had something similar on the rear recently. Sounded like a stone caught in the treads.
Turned out to be a sticking caliper. Worth checking to see if pads on one side wearing faster/wheel hot after a run. Lloyd Barnes
Current
Crendon 427 Sideoiler Cobra in build... 7 litres of madness!
Gone
2008 TDV8 Vogue - Black with Ivory/Grand Black Lacquer
2008 VW Touareg 3.0Tdi
6.3litre Dax Cobra - 12.34 Second 1/4mile at 114mph Smile
Post #159304 22nd Dec 2012 8:32pm
Durham4416
I'd read about the rear Calipers sticking, would explain the lower speed noise, I'll whip the wheel off and see if they are free, I checked the rear wheels for heat the other day just out of interest but they were both cold, maybe not a long enough run
Post #159306 22nd Dec 2012 8:38pm
Durham4416
Re: Rotational related noise
There's no difference in noise if I brake it stays the same until disappearing when I'm almost at a stop
Post #159318 22nd Dec 2012 9:20pm
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
I had this, turned out to be one of the brake dust shields had rotted around the bolts and was wobbling around rattling and touching the disk as it was going round. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #159348 22nd Dec 2012 10:13pm
Durham4416
Cheers ill take a look, cheers up to now everyone
Post #159350 22nd Dec 2012 10:15pm
Common for the splash shield to break off and rub against the disc, easy to repair by removing the bolts and placing a large washer between the plate and the bolt Thumbs Up
Post #159352 22nd Dec 2012 10:17pm
