Home > Technical (L322) > Brake pad change void warranty? |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 |
Hi Mike
29th Mar 2010 4:51am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6366 |
I had fitted pattern brake parts on the TD6 and they were crap. I ended up swapping to genuines fairly soon afterwards.
29th Mar 2010 8:54am |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 381 |
Thank you both! Question. The car only has 20k miles on it. Can the front disc's be turned or do they need to be replaced? Thank you! Mike |
29th Mar 2010 2:00pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3737 |
blimey, 20k miles, what you do drive with your footbrake on . You should be getting 2 sets of pads to 1 set of discs front and rear.
29th Mar 2010 2:06pm |
Best to replace I would suggest. The cost is not that much really (in the UK anyway) and for peace of mind etc. Discovery 4 HSE
29th Mar 2010 3:01pm |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1091 |
Can the brake warning light be reset by me having repplaced the pads or is it a proffit oppertunity for the steeler? letters not necessarily in the right order |
7th Apr 2010 7:27pm |
andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 160 |
the sensor auto resets the warning light so no dealer profit to be had 02 Range Rover HSE Zambezie silver 4.4 |
7th Apr 2010 8:12pm |
