Home > Technical (L322) > AJV8 SC Cold Start Squeak
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Read a few posts regarding this and as its a known problem it has a TSB out that involves replacing the idler pulley and FEAD belt then modding a bracket.
Has anyone done this themself - if so I'd appreciate some info regarding the job. had car about a month and noticed a very slight squeak, car has a warranty but if its an easy job I'd do it myself.
Kit seems pretty cheap and time is only about 1.5 hr so sounds pretty simple.
Apparently issue is caused by belt wandering on pulley and I'm concerned it could result in a shreadded belt.
Thanks
Post #158614 19th Dec 2012 9:58pm
bluearmy
England 2006 Range Rover Vogue 4.4 V8 Java Black
mine has just started doing the same will be interested to see what people say
Post #158627 19th Dec 2012 11:04pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
If it's in warranty, let them do it. Any problems will be their issue, not yours. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #158629 19th Dec 2012 11:32pm
Katash
May get a quote from local LR garage but the warranty I got was from an independant dealer and probably Censored .... Think they have a max hourly rate payout of £35 per hour and the dealer I purchased car from said LR mechanics would probably charge more so take to independant if any issues .... An independant probably wouldnt know about the TSB tho.
Post #158637 20th Dec 2012 6:50am
Yes more like £100 per hour! Most Independents worth their salt down south are £50 per hour. Our warranties cover up to £75 per hour.
Post #158640 20th Dec 2012 8:07am
