![]() | Home > General > TD6 or TDV8 3.6 |
If your wallet can handle it get the TDV8 but the TD6 is a good workhorse if you are looking for a bargain. |
whats your budget is the best question really??
http://www.ebay.co.uk/itm/LAND-ROVER-RANGE...3f1fd730ad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
SAGARIS Member Since: 05 Oct 2012 Location: north wales Posts: 20 ![]() |
thanks for replys chaps, was looking for a very good 06 TD6 or 07\08 TDV8 3.6, budget around £15/17K TVR SAGARIS |
You could JUST stretch to a TDV8 then.
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
I would normally say go for a TDV8, but the cheaper ones are probably cheap for a reason. It may well be worth going for a TD6 with a good warranty or one that has had its gearbox replaced already. You don't want to buy a cheap TDV8 that has expensive problems which ruin you first year of ownership 56 TDV8 Vogue SE
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
For that sort of money i would go for TD6 as you will get a low milage car that has been looked after.
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
^ wot he sez.. |
barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213 ![]() ![]() ![]() |
I had this exact predicament a couple of months ago.
I bought a 2003 TD6 two and a half years ago when the difference between a TDV8 and a TD6 was much bigger. Mine had had the gearbox replaced. Even now I wonder if I made the right decision. If I was buying now I would definitely stretch to the TDV8. I like my car but the engine is really agricultural at times and it's never that refined. On the motorway you're doing nearly 3000rpm which is just too high. It is also really quite slow.
In the uk at least the petrol versions are usually a little cheaper to buy than the diesel counterparts.
lrdaft Member Since: 08 Apr 2010 Location: United Kingdom Posts: 60 ![]() ![]() ![]() |
Go for a supercharged cheaper to buy but better smiles per gallon |
Better smiles per mile, but per gallon? You'd need an awful lot of smiles for that. |
As you know for that budget I would look for a nice 4.4V8 or 4.2V8SC. Just bought another one myself for personal use. Will post soon. |
