Home > Technical (L322) > iBus + Resler Interface + Navcoder |
Tesh Member Since: 27 Feb 2010 Location: Co Durham Posts: 138 |
Dan
26th Mar 2010 10:19am |
Like I said, only connect the iBus data and Earth. Then see how you get on. D |
26th Mar 2010 1:12pm |
Thanks for the quick replys guy's
26th Mar 2010 2:36pm |
well gents I have tried every which way I can and it doesnt work
27th Mar 2010 9:16am |
A bad workman blames his tools. Sorry, no offence intended. BUT it does work, the fact that you can't get it to work does not make IT rubbish. There is of course the posibility that the interface is broken. If you plugged the lead from the CD changer strait onto the board then it will be as the 12v and earth are the other way round. Only if you used the end plug and then a ground wire will it work. If you've punted 12v+ around a sensitive circuit then it may be fried. If you want me to check the board works pm me and I'll send you my address so you can post it to me and I'll check it out for you. PS, I never got intravee to work in my car, I was using all 3 wires. I bet if I used just the two now it would work. I ended up cussing it and selling it on for a loss! Dan |
27th Mar 2010 9:30am |
Dan
27th Mar 2010 9:59am |
managed to get the drivers installed corrwectly
27th Mar 2010 11:04am |
ive noticed with car in drive if i pull the handbrake on one click the tv comes on |
27th Mar 2010 11:10am |
Did you do a "Read" first? this then sets navcoder up for the options you have, rather than its default options.
27th Mar 2010 11:22am |
yes I read first then ticked the 2 boxes then pressed code
27th Mar 2010 11:41am |
It appears to be programming the car but when you test what ever you have programed it hasnt been successful |
27th Mar 2010 12:00pm |
jayzee Member Since: 14 Oct 2009 Location: UK Posts: 342 |
I think to get to this level of detail, and to be successful, you really need to either go to a dealer, or invest in one of those £1k devices (on ebay).
27th Mar 2010 2:45pm |
Success.............................. the TV is enabled
27th Mar 2010 3:10pm |
Maybe you're doing it wrong, or maybe you're a dealer in disguise? There are cheaper options out there, it's a lot more complicated to figure out how to do it yourself though over taking the car to the dealer. But if money is no object then I see your point. |
27th Mar 2010 10:57pm |
