Home > Technical (L322) > l322 height adjustment with BBS faultmate extreme |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35374 |
not many here have this diagnostic tool so you might not get a quick response, have you tried asking on the bbs forum? ... - .- -.
13th Dec 2012 8:03am |
nkc Member Since: 25 Nov 2012 Location: Nigeria Posts: 15 |
thank you, will do so now.
13th Dec 2012 9:56am |
this is from member Joe90's gallery and will give you some idea what the height measurements are..
13th Dec 2012 10:03am |
thank you so much,
13th Dec 2012 10:07am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
That's what the book says. I have a similar problem with LH front being @ 10mm lower than RH front. My diagnostic tools so far have been unable to adjust this. .
13th Dec 2012 10:44am |
exactly my problem, thank you for ur response.
13th Dec 2012 10:57am |
During normal operation +10mm is normal. If you have set the suspension to tight tolerance mode (only 2006>) it should go to +3mm. This is only for servicing such as for an alignment, tho. Leaving it in tight tolearnce mode will throw faults and waer the compressor very quickly.
13th Dec 2012 12:14pm |
thank you so much steve. 2012 Range Rover Autobiography - Faultmate MSV2 Extreme - IID Tool |
13th Dec 2012 7:51pm |
