Home > Technical (L322) > head light fuse help
simonmanx
Isle Of Man 2005 Range Rover Vogue SE Td6 Java Black
Does anyone know where the passenger side dipped haedlight fuse is and the fuse number ??
Post #156504 10th Dec 2012 4:39pm
There isn't one.
As far as I know the lights are protected by FET's incorporated in the Lighting Control Module.
Post #156507 10th Dec 2012 4:54pm
simonmanx
ive got dipped headlight out and was looking for a fuse but it has been flickering for over a year Big Cry
Post #156508 10th Dec 2012 4:55pm
I assume you have checked the bulb? Smile
Is this HID or tungsten bulb?
Post #156509 10th Dec 2012 4:59pm
simonmanx
hid and yes i swapped it
Post #156510 10th Dec 2012 5:00pm
ballast? ... - .- -.
Post #156514 10th Dec 2012 5:03pm
simonmanx
im tinking the same has anyone purchased one from ebay ???
Post #156516 10th Dec 2012 5:07pm
Before going for a ballast it might be worth checking to see if you have 12V at the headlight.
Post #156519 10th Dec 2012 5:33pm
simonmanx
ok will check Thumbs Up
Post #156521 10th Dec 2012 5:34pm
You could also change the ballast from the other headlight to double check.
Post #156522 10th Dec 2012 5:36pm
