Home > Technical (L322) > head light fuse help |
simonmanx Member Since: 17 Feb 2010 Location: Isle of Man Ballasalla Posts: 157 |
Does anyone know where the passenger side dipped haedlight fuse is and the fuse number ?? |
10th Dec 2012 4:39pm |
ive got dipped headlight out and was looking for a fuse but it has been flickering for over a year |
10th Dec 2012 4:55pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
I assume you have checked the bulb?
10th Dec 2012 4:59pm |
hid and yes i swapped it |
10th Dec 2012 5:00pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35423 |
ballast? ... - .- -.
10th Dec 2012 5:03pm |
im tinking the same has anyone purchased one from ebay ??? |
10th Dec 2012 5:07pm |
Before going for a ballast it might be worth checking to see if you have 12V at the headlight. |
10th Dec 2012 5:33pm |
ok will check |
10th Dec 2012 5:34pm |
You could also change the ballast from the other headlight to double check. |
10th Dec 2012 5:36pm |
