Home > General > 83k Miles TDV8: What Should I Be Refreshing / Repairing |
Bomber County Member Since: 12 Dec 2011 Location: Dunston, Lincoln Posts: 81 |
Hello All,
9th Dec 2012 8:46pm |
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 |
Just done the same, now just under 100k so from my experience...
9th Dec 2012 11:01pm |
thanks guys,
10th Dec 2012 8:41am |
I'd look at maybe getting a gearbox flush as RRUK did as this will help the box last longer as clutch materials wear within the box and contaminate the oil its best to change it and at 5 years old now is a good time for it
10th Dec 2012 9:53am |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
I used to think the same about oil changes, even changing mine more regularly than needed. Then I read a post on another forum by a guy whose job is to test oils. This is his response when I asked him his opinion on oil change intervals?
He also made this point.
So it's likely that the oil change intervals specified in 2006 when the TDV8 was new are probably very conservative for today's oils. |
10th Dec 2012 12:28pm |
TBH i have seen a fair few engines reach high miles and its not only down to their usage but their service regime.
10th Dec 2012 12:57pm |
Bomber - the replacement was completed under warranty so I don't know the cost for sure. I beleive it was over £1k but was an absolute pain to trace the fault which took over 3 days to find with half the cabin stripped out (or so I was told). |
10th Dec 2012 4:06pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8673 |
What symptoms did you guys get from the sticking rear calipers?
10th Dec 2012 9:52pm |
I had no discernible symptoms until they were really grinding, at which point you could clearly hear them as you slowed (and sometimes when driving at constant but slow speeds). I could not feel any hesitating when accelerating |
10th Dec 2012 10:09pm |
rwilson Member Since: 17 Jan 2011 Location: London Posts: 84 |
Excess brake dust on rear wheel/s and heat build up, rather like a stuck on handbrake. Then of course if you havent noticed that and the warning light fails to go off, metel on metal! Been there done it!!! |
13th Dec 2012 6:49pm |
