Home > Technical (L322) > Sounding Out Top Hose Issue, Updated and Solved |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 |
Ive searched the forum and seen the same sort of question but i wanted to sound out my theroy
3rd Dec 2012 5:54pm |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
I had exactly the same problem with mine - that pipe blew off - happened to me a few weeks after the expansion tank cracked. Just replaced the pipe assembly and all has been good since (20,000 miles). I think the plastic for the pipe connector is the same stuff as the expansion tank, so it made sense (to me) that they should both fail at about the same time.
4th Dec 2012 4:57pm |
Roystonh Member Since: 21 Nov 2011 Location: Kent Posts: 395 |
Mine went to on a 2011 Vogue after 19k miles. Hose replaced under warranty - but took them a month to sort it out. All ok now. 2005 L322 Vogue Gold gone
5th Dec 2012 12:15am |
Ok update, ive fitted the new pipe and a new thermostat and now the car is running at 85c max
9th Dec 2012 8:27pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
What temperature does the coke cope with in winter .
9th Dec 2012 8:46pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Coke trick? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
9th Dec 2012 9:40pm |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
Use the bottle to get a head of water. Obligatory use when bleeding cars with a low expansion tank. Citroens bleed better using a lemonade bottle rather than the coke version. |
10th Dec 2012 9:01am |
My mate at BMW taught me ages ago, get a empty 2ltr bottle fill with water remove the little plastic ring from the lid seal at the top of the bottle Then the bottle neck seals to the neck of the expansion tank and leave it there y u run up the car, ur see air bubbles coming out and the bottle flexing u might want a extra bottle on stand by, rev the car etc ur see the air once ur happy put ur cap on job done |
10th Dec 2012 1:50pm |
