Home > Technical (L322) > Sounding Out Top Hose Issue, Updated and Solved
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Ive searched the forum and seen the same sort of question but i wanted to sound out my theroy
Had the top hose blow off on the input into the engine, the factory metal ring clamp still in place ubt the endge of the plastic ribbing looked worm and ruff on the last edge
This link here states problems colour change etc all off which ive had
http://www.youtube.com/watch?v=Vlps-QQ48vw
Now i managed to convince the AA bloke who come out to me to bodge the pipe back on with a jublie kit, just my luck i got the AA guy who had worked for them for 5days and waned to do everything by the book Big Cry
Anyway he got me a clip, presure test the expansion cap, pressure test the cooling system and everything was holding.
He then got his diagnostics kit out and stated the temp rised to quick and the car was sitting at 103c, i told him that wat was stated as normal running temp but he sh*t a brick and said it was AA policy to get it recovered home.
Well i drove it home and the needle stayed dead centre and didnt move, also i run the Intravee diagnostics on my screen and monitored the temp the car sat at 228-233F which seems a little high however it drove home lovely.
Ive decided to replace the pipe and thermo with housing and sensor which ill be doing this week
Is this a common issues with RR?? its done 65000 miles it seems the pipe and thermo go alot but i just wantd ur thoughts on the above
thanks
NEil
Post #155123 3rd Dec 2012 5:54pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
I had exactly the same problem with mine - that pipe blew off - happened to me a few weeks after the expansion tank cracked. Just replaced the pipe assembly and all has been good since (20,000 miles). I think the plastic for the pipe connector is the same stuff as the expansion tank, so it made sense (to me) that they should both fail at about the same time.
Temperature sounds bang on right.
Post #155330 4th Dec 2012 4:57pm
cliffy
Quality cheers
Yeah my expansion tank went as well lol
I'm also gonna do the water pump while I'm at it to be on the safe side id rather buy and replace now than get more grief later
Post #155491 4th Dec 2012 10:38pm
Roystonh
Mine went to on a 2011 Vogue after 19k miles. Hose replaced under warranty - but took them a month to sort it out. All ok now. 2005 L322 Vogue Gold gone
2006 L322 Vogue Black gone
2011 L322 Vogue Silver gone
2011 L322 Autobiography Black gone
2015 L405 Autobiography LWB Black gone
2019 L405 P400e Range Rover Autobiography LWB Eiger grey / black roof gone
2001 P38a 30th Anniversary Wimbledon Green gone
2019 L405 P525 Autobiography LWB British Racing Green
Post #155511 5th Dec 2012 12:15am
cliffy
Ok update, ive fitted the new pipe and a new thermostat and now the car is running at 85c max
im well pleased, the electric connection on top of the old thermo had rusted out so it was mullered
I changed the pipe without removing the fan i just raised the car up and dropped the under tray plumbed in the pipe work and she was sorted, bleed the system out with my bmw bleeding trick using a 2ltr bottle of coke and its brilliant
Post #156364 9th Dec 2012 8:27pm
What temperature does the coke cope with in winter Question Laughing .
Post #156369 9th Dec 2012 8:46pm
Coke trick? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #156386 9th Dec 2012 9:40pm
steptoe
Rob2529 wrote:
Coke trick?
Use the bottle to get a head of water.
Obligatory use when bleeding cars with a low expansion tank. Citroens bleed better using a lemonade bottle rather than the coke version. Mr. Green
Post #156422 10th Dec 2012 9:01am
cliffy
Rob2529 wrote:
Coke trick?
My mate at BMW taught me ages ago, get a empty 2ltr bottle fill with water remove the little plastic ring from the lid seal at the top of the bottle
Then the bottle neck seals to the neck of the expansion tank and leave it there y u run up the car, ur see air bubbles coming out and the bottle flexing u might want a extra bottle on stand by, rev the car etc ur see the air once ur happy put ur cap on job done
Post #156459 10th Dec 2012 1:50pm
