![]() | Home > Technical (L322) > Strange Noise |
where are you in the UK?? It may help if someone else who knows the FBH sounds could listen?
jonlewis Member Since: 06 Nov 2012 Location: UK Posts: 308 ![]() ![]() |
Well autochanger rule out, had the noise last night when i got in the car at a cold and wet station.
benjj Member Since: 27 Feb 2012 Location: North Yorkshire Posts: 116 ![]() ![]() ![]() |
Have you checked the passenger side mirror?
Almost captured the noise today, but by the time I had my phone ready it had stopped. From the outside it sounds very dodgy. |
Managed to get a recording of the noise. This is from outside, and while a bit constant on the recording is normally a little more random
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
sounds like a pulley? where in the engine bay is it coming from? There is nothing that can't be fixed with a hammer😜😜
Not sure yet. Only occurred to me afterwards to open the bonnet, but by that time the noise had stopped.
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 908 ![]() ![]() ![]() |
Now that I've heard it, I have that noise too. |
Underneath the battery area...... Happened again as soon as I got in........got the bonnet up just in time. 2011 Stornaway Grey 5.0SC Autobiography |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Sounds like the FBH. My one makes the same noise. Only hear it at this time of the year when it switches itself on. Never a squeak or groan for the warmer months. Previously..
And... You do know the FBH is located under the battery? |
When i switch it on manually, it sounds nothing like that though......... 2011 Stornaway Grey 5.0SC Autobiography |
Done another check by switching the FBH on with the bonnet open. Not the same sound. The FBH is a constant low level noise which is not overly intrusive. The other noise is actually quite invasive into the cabin and sounds alot louder
Thelord67 Member Since: 19 May 2012 Location: Stockport Posts: 27 ![]() ![]() ![]() |
I am staggered, I have the exact same noise! I look forward to it being diagnosed...
