![]() | Home > General > What feature is this on the instrument panel (Front PDC?) |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
What does the manual say???? Does it come on when you are about to hit a wall or hit a car at speed? |
Mavromatis Member Since: 01 Dec 2012 Location: Washington Posts: 12 ![]() ![]() |
That's the issue -- I can't get it to show up. It's not the front PDC because that I need to press the PDC button for the front to engage (or be in reverse). It's no where in the manual either.
So if you have cruise on, and you come up behind a car, does it indicate in some way that it is adapting the cruise control? I would have thought there would be a warning of sorts? Previously..
Oh, and welcome to the forum |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
I believe it's for setting the gap on the adaptive cruise control |
Interesting -- will try that out. |
oldcro Member Since: 17 Mar 2012 Location: Shetland Posts: 359 ![]() ![]() ![]() |
As Simon1233 says it is the gap chosen for the adaptive cruise control, it goes up to 4 chevrons selected by the 2 buttons behind the cruise control buttons. It is a time gap not a distance gap so the actual gap shortens at slower speeds within the low speed range of the ACC. |
As above its the ACC gap. I think it goes to 4/5 Arrows but can go down to 1 |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
In the words of Jeremy Clarkson: "You can go from polite to full on Audi with the Jaguar ACC" |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
Comes up on the display when you select 'set' and displays 3 chevrons. Also comes up if you use the buttons under the wheel as they allow you to decrease to 1 or increase to 4.
Testbook or maybe Faultmate could do this as im guessing it would be in the CCF file somewhere |
